Televison & Video Logo
Posted on Aug 06, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
BOW PICTURE AND HUE GREENS REDS AND BLUES LIKE SHADOWS
I HAVE A ZENITH 55INCH PROJECTION HDTV, WHEN WE CONERTED TO THE CONVERTER BOXES IT MESSED UP MY SCREEN. MY PICTURE ON THE SCREEN IS BOWED AND IT HAS SHADOWS OF RED, GREEN AND BLUES. PLEASE HELP ME NEVER HAD A BIG SCREEN AND IT WAS USED BUT IT DID SHOW A GREAT PICTURE.
Anonymous
Level 3:
  • Master 476 Answers
  • Posted on Aug 06, 2009
Anonymous
Master
Level 3:
Answers
476
Questions
0
Helped
101245
Points
1473
The tv had intermittant solder connections already but h\they appeared when the tv was moved to hook up the digi-box. The solution could be as simple as resoldering the power convergence amps.
Have a model 55pw9383/17f that had convergence issues for a while. The reds, blues and greens were all seperated. Now I turn it on and have no picture.
Your convergence has failed and needs to be repaired.You can call in a repair shop or you can get the parts and instructions from www.TvRepairKits.com and do the repair yourself. Its a fairly easy DIY fix.
Something has happened to the color on my tv. it's lost the reds in the picture. face color is good. pinks, blues and greens are ok. i've unplugged and re-started. how do you go back to default...
Look for color temperature settings under the menu and video settings. If there is an overall factory reset or restore to factory settings, try that as a last resort.
1helpful
I have a 46" rear projection Mitsubishi TV that recently started producing a wavy picture. The reds, blues, and greens separate into wavy color bands distorting the picture. It usually goes away for...
your problem is most probably in convergence circuit.  very common for this model to have convergence output i.c.'s go bad  also possible that a fused resistor or two has failed.
Color doesnt line up
Need to use convergance, if you cant do it from your remote go to menu and align.
I installed a new color wheel in my 6167w 61 inch hdtv. Now my colors are all messed up. Like the reds and blues are backwards.
You must go into service mode and re-align the registers, if you've never done this you must call a qualified svc center. Most color wheel replacements require re-alignment. The DLP must match the speed of the color wheel.
I have a ws-a65 tried to install 1080 hd quality through At&t u-verse missing green and red color only shows yellows and blues help!!!
im just going to assume you have it hooked up wrong, call a TV person and they can come look at it, its really hard to do this kind of thing over the internet
Toshiba 50H71 projection tv
the convergence ICs have shorted and thats whats shutting down the set. Its an easy repair you have to replace both the Convergence ICs they are STK392-110 ICs you can get replacements at the following link and they provide free instalation instructions with pictures and also free tech support. Heres the link.
http://servicemanuals.vstore.ca/
2answers
You need to replace both of the convergence ICs they are number STK392-110 you can get new replacement ICs at the following link and they provide free instalation instructions so you can do the repair yourself which tkes about 30 minutes to do and saves you about 400 dollars. heres the link.
My phillips model 60pp920217f has a horrible picture...no green to the color
The green CRT coolant has congealed thats whats giving you the green halos. Change the coolant in the green and blue and your set will be fine. red is never affected so the red coolant should be fine.
Color distortion issues
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
