20 Most Recent Philips 43PP9202 43" Rear Projection Television Questions & Answers
0answers
I Specifically have a 2005 Phillips 50" Projection
on your remote go to menu,then push picture then scroll down to converge then depending on what color is out of line you will push that,then what ever is out of line you line it up by the up arrow.if that don;t work then there are parts on your board gone bad.
2/19/2013 7:23:30 PM • Philips 43PP9202... • Answered on Feb 19, 2013
2answers
Cloudy TV Screen
If you can remove the front screen, look down into each CRT tube lens, blue, green & red see which ones are cloudy. The cloudy ones need the fluid changed which is a coolant. Shops charge between $75 to $150 a tube to change.
2/11/2013 7:17:36 AM • Philips 43PP9202... • Answered on Feb 11, 2013
Red Screen Philips 43PP9202 Projection Television
check all the lamps if all working.
7/19/2012 12:17:25 PM • Philips 43PP9202... • Answered on Jul 19, 2012
Where can I find instructions
You can send me a email to [email protected] and I will email you the user manual for your model which will have the info on adjusting convergence.
8/19/2011 2:52:37 PM • Philips 43PP9202... • Answered on Aug 19, 2011
Tv picture settings for
If you cannot align RED, BLUE, or Green your TV has a convergence failure. You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
1/22/2011 8:32:00 PM • Philips 43PP9202... • Answered on Jan 22, 2011
Red and green do not
Your TV most likely has one of two possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc
12/15/2010 7:26:36 AM • Philips 43PP9202... • Answered on Dec 15, 2010
There to much glare (white)
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs.
You can find more details and solutions here on Fixya at the following link below. Or click HERE
3d884ac.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
10/15/2010 2:25:37 AM • Philips 43PP9202... • Answered on Oct 15, 2010
The TV screen is blurry/fuzzy
You have Bad Coolant fuild in Tubes need to do a fluid change
Mats Electronics has Coolant Fuild 1-800-628-1118
9/28/2010 11:06:29 AM • Philips 43PP9202... • Answered on Sep 28, 2010
I am putting in the convergence IC's and want to
there can be between 2- 12 look near the STK chip
and see how many there are.Depends on the type and model of TV
9/3/2010 1:41:01 PM • Philips 43PP9202... • Answered on Sep 03, 2010
43pp92 philips 43" HDTV blue convergence went out of whack
Get a convergence kit from www.TvRepairKits.com
6/6/2010 5:44:13 AM • Philips 43PP9202... • Answered on Jun 06, 2010
Why do I have a hazy picture
A common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
6/6/2010 5:43:45 AM • Philips 43PP9202... • Answered on Jun 06, 2010
Slow to turn on Phillips flat screen tube big
That is a common issue with the last generation of the phillips big screens, the best answer for this is one that i got at a meeting with phillips service several years ago. On philips the tv will not show a picture till the tubes are balanced out, simular to sony, but in a phillips if the white balance is not correct the picture and sound will be muted till all three tubes have warmed up enough to produce a good white balance. As the set ages the tubes become weaker and this procesess takes longer.
5/7/2010 8:09:37 PM • Philips 43PP9202... • Answered on May 07, 2010
Intermittently screen move to one side with distrited picture
Might be the convergence chips. Do you have any problem moving the convergence under the menu setting? Convergence chips are reasonably priced. If you know a friend or someone who can solder better than average, I would go this route. My tv wasn't that bad; I wasn't able to set 2 of the 3 colors during convergence setup. Changing the 2 convergence chips did the trick!
3/31/2010 5:50:43 PM • Philips 43PP9202... • Answered on Mar 31, 2010
White haze and very unclear picture. Seems the
Search for "coolant change projection tv", there are several good links including where to buy the coolant. I did mine yesterday and it's like having a new TV again, all for about $20 and 3 hours time.
12/21/2009 6:12:20 AM • Philips 43PP9202... • Answered on Dec 21, 2009
Philips 43PP9202 43" Rear Projection Television Logo
102 questions posted
Top Philips Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Philips Televison & Video
Most Popular Question
tv screen blurry fuzzy
  • Televison & Video
