SOURCE: GE Blender Jar loose rotator
Remove the bottom clean the unit fully. Add the bottom blad assebly and this will fix your problem. The "sooty" is plastic shavings. Take note that the fitting were the "jar" connects to the motor that this is not wearing away. The unit i have broke and i am unable to find a replacement blade assembly.
SOURCE: My kenmore blender stopped blending!!!
There is a gear underneath the blender blade. This connects the blade to the motor found on the base of the blender. This gear usually get worn out specially if the load that we are giving to the blender is beyond its limit. I hope you could by a spare on one of the electric shop near or might as well consider buying a new set.
Testimonial: "Thanks i just cant find where the sell the parts at but you really helped me!!!"
SOURCE: How do I fix or
Make sure the blade assembly is put together in the correct order. The blade needs to go through the gasket so that the order is pitcher glass, gasket, and metal blade base. Then the final plastic cap threaded onto the pitcher. If the gasket is not between the pitcher and the metal blade assembly, you will have leaks.
Also, check the gasket to be sure it's not cracked and that it doesn't have residue on it.
I hope this helps. If it does, please come back and rate my suggestion!
SOURCE: how to replace a blade assembly on a waring
Hi, plz try this link if it works: http://www.beveragefactory.com/refrigeration/blenders-juicers/blenders/MBB518.shtml
SOURCE: Waring Pro Blender is leaking and blade assembly is loose
I know this is an old, old post, but I could not find a solution anywhere, so hopefully this will help someone. We have a model 51BL25, similar to scottman55's blender, and it had the same problem. There are two separate nuts in the blade assembly. One holds the blade on, and the other holds the seal tight. When the latter gets loose, the blender shakes and leaks.
To fix it, first you have to remove the top nut holding the blade on. I had to get in there with pliers, but a ratchet with an extension would be perfect. This nut is right-handed ("normal"). Once that nut is loose, you can remove the nut and the blade. You will also want to remove the washer immediately under the blade (take note of which side goes up).
Now, you can pull the whole axle out by the wheel on bottom of the blender. This exposes a really thin, flat nut. In my case, this nut had come completely off, so nothing was really holding the seal together at all. Again, make sure you remember which direction the nut goes -- it is not quite symmetrical. That nut is what comes loose when the blender starts leaking. By the way, it is a left-handed nut, so it screws on counter-clockwise ("backwards"). Screw it in tight, then put the rest of the blade assembly back together, and your done. If you have the right tools, it should take only maybe 5 minutes.
Depending on your problem/model, this may or may not solve your problem. Hope it helps!
