SOURCE: JVC head unit problem
Do you have a "RESET" button on your stereo? Check your owner's manual to find it. I have a JVC unit in my car and the reset button is a small hole behind the detachable face. Take the end of a pencil or a pen and insert it in the tiny hole and hold for a few seconds. This should reset the stereo so you can get the CD out. Hope this helps...
SOURCE: jvc kd lx111 deck wont eject cd
I just had this problem today and when I attempted to eject the CD it would give me an error message that stated (ERR 32). Apparently this means that there is something blocking the movement of the screen, a little manipulation should help the issue. Another variable could be the Eject lock feature, essentially a "child lock" for your disc. When this lock is activated it prevents the CD in the deck to be ejected. You can change this by holding down the blue source button and the eject button simultaneously for about 2 or 3 seconds. A message should appear saying "No Eject" and one that repeatedly flashes "Eject on" These two things seemed to help me alot when I had this issue. If those things don't work I would recommend calling JVC, much to my suprise they were actually really helpful. Their number is 1-800-252-5722.
SOURCE: cd won t eject from 2006 Ford Focus mp3 player Get
HI, either the deck assembly is jammed or, the load motor has failed. In this case, you will need to disassemble the entire set in order to retrieve this CD.
The actual loading deck(the part where the CD is located), is surrounded by a metal housing. the gear assembly is probably locked, due to this jam or failed load motor. This will also require a set of precision tools as well. if you find this a bit overwhelming, i suggest taking this unit to a local automotive audio shop. they can dissemble it and, retrieve the CD for a small price.
SOURCE: how to unlock protected mode on a jvc 5 disc cd changer?
cheack the speaker wireing.if thats not the pro i sugg the repair shop your unit could have over heated.
A malfunctioning stereo may least allow feature buttons to perform extractions of CDs. Depending on how the stereo was installed, the car would have to be powered on to attain stereo functionalities. Second, CDs have to be inserted with the readable media side facing the appropriate lenses to achieve results. A wrong insertion of the CD into stereo compartment may require forceful extraction. Observe the type of stereo to ascertain CD extraction also known as reset buttons. Usually a tiny area, the reset button allows inserting an object that forces the car stereo to eject stuck disks. Every mean to eject stereo disk have to be performed while the car is turned on to utilize the source of power. An unsuccessful attempt to dislodge CDs in stereo compartments would require auto electrician's consultation. An unsuccessful dislodge attempt usually requires acquiring a new stereo in replacement of the malfunction.
