20 Most Recent
JVC AM FM CD DET FACE CAR STEREO Questions & Answers
JVC KD-S15 setup - How do I turn "Demo" Off?
press and hold the sel button....select an itenm (useing the silver button beside the volume dial).....then use the volume dial to adjust ,time , demo alot of others...then press sel button to finish.....this is straight out of the instructions...hope it helps you
JVC KD-HDR60 has stopped responding
I had the exact same problem on my unit the other day. I spent a couple of hours trying to fix it. Did the reset button button behind the faceplate and the I couldn't get the unit on at all. I found the if you push the power/source button as soon as you put the unit on the power would turn back on, but buttons still wouldn't work. After trying several different combination, I started hitting the UP arrow button (which is the program buttons) as fast I could for about 10 seconds and the unit started working. Might have been lucky, but it worked for me.
I have a jvc kd-r311 radio in my car which has
If you have a multimeter, try checking the speakers and speaker wires for shorts and/or grounds. Make sure your speaker wire has no bares spots. If the speakers and speaker wires all check out good, you may have a bad internal output ic.
JVC CD player won't turn on, but will eject CD and display time.
Make sure the red wire is still connected or make sure the red wire
hasn't been severed. Also, check the fuses located in the engine
compartment. The red wire connects accessory terminal in the fuse
block. Also check the fuses in the cabin. This fuse box is typically
located on the driver's side, at knee level, next to the door panel,
and underneath the dashboard. As a last resort, the unit can be taken
to an authorized or factory service center.
JVC KD-R610 is stuck in Protect mode
Try disconnecting your battery, reconnecting it, and resetting your stereo. If that doesn't work, the constant power (yellow wire) or ignition wire (red wire) may have come in contact with ground or isn't properly connected. Make sure everything is connected properly and try resetting your stereo. If it is still flashing "protect", the unit needs servicing Contact JVC Customer Care Center at: 800-252-5722.
How do i use and install the mounting kit
Didn't the deck come with the mounting kit and instructions? Usually they even give to a cut-out template. Please contact JVC and ask for the installation paperwork. You might consider taking it and your car to a stereo installation shop to have it professionally installed.
How to set the color on my faceplate. It contnues
You're stuck in DEMO mode. When you see stereo's on display at a store it is set to a DEMO mode that cycles through colors, functions, etc so that potential customers can see the different aspects of the unit. To get it to stop changing colors you'll have to go into the menu and turn DEMO OFF.
How to save FM radio
Try this, tune to the desired radio station and holdpress the station number ( 1-6) for a while, it should blink twice to confirm its storage.
Ekamave
Jvc Kd-s79bt
This answer is found on page 16 of manual. goto BT mode and Press and hold [MENU]. Select
[BLUETOOTH]->
[DELETE PAIR]->[PHONE NAME]-> [DELETE YES]->DELETED!
Have stereo yellow wire to battery, black wire to
I suggest you ensure the ground is made to a sensible ground point and the supplies are also good and the antenna is also properly grounded and then monitor the supply voltage and the current consumed by the radio until it begins to distort. If the voltage and current remain steady the fault is either local interference or inside the radio, probably in the tuner.
If the current climbs and the voltage remains steady the fault is likely in the audio section...
