SOURCE: TV Tuning on ALBA TV with DVD player
you start with tv,dvd mode to your remote control when you have alread make sure your in tuner you hit menu mode and show you the instruction select arrow shows _ + try it.
SOURCE: byd:sign under the counter TV/DVD player
Did you try using the volume button *on* the TV rather than your remote control? If so, did it work? If it did work, then the problem is with your remote control and you should get a new one.
SOURCE: byD sign d:5032 50 in. HDTV-Ready Plasma
If you purchased from a major retailer, could you try going to another store?
Also try contacting the manufacturer. Hopefully you are still under some kind of warranty, even if the place of purchase is no longer there.
Just to be sure, have you tried a different source - like a video camera, still camera with video output, laptop, or a different DVD player?
Good luck, I hope you can get it fixed!
SOURCE: Power Adapter
I have a new OEM power supply for this tv.
If interested, email me your contact info.
Thanks,
Art
SOURCE: I'm trying to program my
If your brand of TV does not respond to the remote control after trying all of the codes listed, or if your brand is not listed at all, try searching for your code.
1. Turn on your TV.
2. Press and hold SETuntil the Red Light blinks twice, then release SET.
3. Enter in 9 - 9 - 1. The Red Light will blink twice.
4. While pointing the remote control at the TV and press and release the CH + key until the TV turns off. (Note: You may need to press [CH+] numerous times).
NOTE: In the search mode, the remote control will send IR codes from its library to the TV.
5. Press SETonce to lock in the code. The Red Light will blink twice.
