20 Most Recent byD sign d:1070 DVD Player Questions & Answers
How to fix the dvd player that won't play or read
there can be a problem of laser assembly or spindle motor if u sense the vibrations after loading disc then the problem might be of OPTICAL PICKUP (LASER) assembly in dvd player & there is only solution to replace the assembly
2/21/2010 10:45:30 AM • byD sign d:1070... • Answered on Feb 21, 2010
ByD sign 32 inch Led TV does not turn on , it only turns on now and then .
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary. Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
7/13/2016 7:44:44 AM • byD sign... • Answered on Jul 13, 2016
What can I do with a malfunctioning by Dsign TV and where can I have it fixed?
I am assuming this is the board you need... I would take the old one out and see if it is the same part # first! Byd 40 4032 782 L40D11 6900 Terminal Board Unit
5/24/2016 5:48:27 PM • byD sign... • Answered on May 24, 2016
How do I perform a channel scan?
Refer its user manual for details.
5/16/2015 6:19:02 PM • byD sign... • Answered on May 16, 2015
Refriferator, light come on but motor does not run, how can it be fixed?
Dumb answer, but have you turned down the thermostat to a lower setting?
2/15/2014 7:25:15 AM • byD sign... • Answered on Feb 15, 2014
0answers
No stereo sound
first this needs to know if set has internal left and right speakers
9/1/2012 3:19:06 PM • byD sign... • Answered on Sep 01, 2012
Where can i buy a new remote mine got water damaged
It depends on the TV (make/model). Do you have an Input or Source button on the TV? Then you can use that button to change your input. A few models will offer an alternative option to change the source from the menu and have a Menu button on the TV. (Some TVs only let you change the source from the remote.)Some remotes are available from the manufacturer's parts store (Sony, for example). remotes.com has the exact original or a replacement remote for many brands. For other TVs, a universal remote may work. Look for a higher end universal remote with a Source or Input button. Then test all of the codes for your TV brand. (Some codes may only enable parts of the remote functions; make sure you find a code that lets this button work.) The remotes that can be programmed with a USB connection to a computer are the easiest to set up for this situation. Please add a comment with the specific make and model of your TV; I'll try to find a source for an exact replacement remote. Cindy Wells (some really old TVs let you swap from AV1 to AV2 to channels by going up or down through all channels to reach a point where you could swap the inputs.)
2/3/2012 5:50:07 AM • byD sign... • Answered on Feb 03, 2012
I have a d:4742m 47
No pictures can be due to no 24vdc for the backlight, bad T-CON board (have backlghts but no pictures).
Please try below first:
First, look at the screen in darkened room to see if you can see any slight glow from the screen, if it does, then the problem can be the T-CON (not getting the 12vdc) or the main logic board not feeding the signals to the T-CON board. if not, next place to check will be the power supply module, make sure it has 24vdc which is required by the backlight inverter to work, the reason for not having 24vdc can be from bad DC filter caps (leaking/bulging top, high ESR) or short circuits in the inverter board which will cause the 24vdc supply to go into shutdown mode, so you may have to disconnect the power cable that feed the inverter board to see if the 24vdc will work without the inverter board hookup, you will need to apply about 3~4 amp of load to the 24vdc to make sure it can handle that. There are fuses on the backlight inverter boards also. So there is some troubleshooting you will have to do to find out the causes of the problem you are having. If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on: Basic LCD monitor and TV troubleshooting guide: http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting http://www.fixya.com/support/r7406380-tv_training_manuals Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague Parts: www.shopjimmy.com Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps. Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series. Please post back what you find.
12/28/2010 5:17:24 AM • byD sign... • Answered on Dec 28, 2010
I need a new power
Most of the flat pannel tv have a standard D shaped removeable cord. all most all computer pc's use the same cord. they should all be three prong. unless you are not in the usa. Most people will have atleast one of them around. good luck.
8/30/2010 2:32:36 AM • byD sign... • Answered on Aug 30, 2010
2012 troybiilt super pony transmission axel is trying to slide out how to fix it
The axles may have substantial amount of in/out play, 1/4 inch or more. Does the axle in question actually drive the wheel or does it freewheel?
It's a typical differential so if you get both wheels off the ground and spin one wheel, the other wheel should rotate in the opposite direction.
The axles are retained by the differential assembly (inside transmission) so if the axle is truly falling out, to fix it will require transmission be removed and opened. Probably not an economical repair unless you can DYI or replace with good used unit.
4/19/2024 9:41:16 PM • Televison &... • Answered 1 hour ago
What is the sky remote code for a cello model c20234f-led ?
Turn on your Sky Box and TV. On your Sky Remote, press the TV button. Simultaneously press the Select and Red buttons until the red LED on your remote blinks twice. Enter one of the following 3-digit remote codes for Sky TV: 2274 2169 1874 1798 1872 1873 The light on the remote should flash twice. If it blinks only once, repeat the steps with the next code. Press the Standby button on your remote. If your television turns off, press the Select button to save the setting. Turn on the TV and press TV Guide; if the TV Guide list displays on the screen, the programming was successful. Remember that there are multiple versions of Sky Remote Controls available, so ensure you have the most recent version. If you encounter any issues with the 3-digit codes, you can also try using a 4-digit code. Here's how: Repeat steps 1 to 3. Enter the 4-digit Sky remote code for your TV brand. Press the Standby button. If your TV turns off, press Select to save your settings. Check if the TV Guide displays successfully on the screen. Sky TV Remote Control Codes
4/19/2024 8:32:21 PM • Televison &... • Answered 2 hours ago
2answers
Harwa 32 Inch Led Television. How do I update my software on my Harwa 32 inch as my apps show it needs an update.
To update the software on your Harwa 32-inch TV, follow these steps: Check Other Solutions First: Before proceeding with a firmware update, ensure that you've tried other troubleshooting solutions. Sometimes issues can be resolved without updating the firmware. Gather Necessary Items: You'll need the following: A computer with an available USB port. A high-speed internet connection. A USB flash drive. Find Your TV Model Information: On your TV, navigate to the Help menu and select System Info. Write down your TV's model, revision, and firmware information. Download the Firmware Update: On your computer, visit the Insignia Products website at www.insigniaproducts.com. Click on Support & Service. Enter either NS-19D220NA16 or NS-19D220MX16 in the search box under Manual, Firmware, Drivers & Product Information. Follow the Firmware Installation Guide: Download the firmware update from the Insignia website. Copy the firmware file to a USB flash drive. Install the Update on Your TV: Plug the USB flash drive into the USB port on the side of your TV. Press the MENU button on your remote. Navigate to HELP and press ENTER. Highlight Update Firmware and press ENTER. Confirm that you want to update the TV firmware by selecting OK. Your TV will display a status screen while installing the update. Do not turn off your TV during this process. Once the update is complete, unplug the USB flash drive and press ENTER. Your TV will turn off and then back on to finalize the update. Rescan for Channels (if needed): If your channel list has been deleted, you'll need to scan for channels again. Refer to your TV's manual for instructions on how to do this. Remember: If you encounter a message saying the firmware file is incorrect, ensure you've downloaded the correct file for your specific model. If the update fails or your TV screen remains blank with a blinking red then blue power LED, turn off your TV, turn it back on, and run the upgrade again.
4/19/2024 7:23:41 PM • Televison &... • Answered 4 hours ago
Need a new remote control for iheater ih1500--how much does it cost and can you ship it to me? model IH1500 Serial IHA080939250
Sorry, we do not supply anything. I would aproach the supplier or manufacture for advice and spares availability.
4/19/2024 3:13:01 PM • Televison &... • Answered 8 hours ago
Sorry, but we do not supply parts. This is a website for advice on repairing items. You could try contacting the store you bought it from or contacting iheater directly.
4/19/2024 3:12:50 PM • Televison &... • Answered 8 hours ago
Where is the Google on the Matertech?
It appears that there could be miscommunication. As of my previous update in January 2022, Matertech doesn't seem to be a commonly known term or corporation. On the other hand, if you're talking about "Google," it's a well-known worldwide technological corporation that specializes in internet-related services and goods, such as search engines, cloud computing, online advertising technologies, software, and hardware. Google's official website or an internet search utilizing one of the search engines like Google itself are usually the easiest ways to get information about Google. If "Matertech" relates to a particular thing or idea, further information could be helpful in order to provide a more precise answer.
4/16/2024 4:37:21 PM • Televison &... • Answered 3 days ago
byD sign d:1070 DVD Player Logo
2 questions posted
Top byD sign Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
Are you a byD sign Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • byD sign Televison & Video
Most Popular Question
fix dvd player play or read
  • Televison & Video
