20 Most Recent
byD sign d:4232 42 in. HD-Ready Plasma Television Questions & Answers
No picture
btw for anyone experiencing these problems with the infamous "is-lcdtv32" byd:sign is the same manufacuterer as insignia, its the same company with a different sticker. i know this isnt a solution, but parts for all discontinued insignia';s can be purchased thru byd:sigh(by design). hope this helps .
ByD sign 32 inch Led TV does not turn on , it only turns on now and then .
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
7/13/2016 7:44:44 AM •
byD sign...
Answered
on Jul 13, 2016
No stereo sound
first this needs to know if set has internal left and right speakers
9/1/2012 3:19:06 PM •
byD sign...
Answered
on Sep 01, 2012
Where can i buy a new remote mine got water damaged
It depends on the TV (make/model). Do you have an Input or Source button on the TV? Then you can use that button to change your input. A few models will offer an alternative option to change the source from the menu and have a Menu button on the TV. (Some TVs only let you change the source from the remote.)Some remotes are available from the manufacturer's parts store (Sony, for example).
remotes.com has the exact original or a replacement remote for many brands. For other TVs, a universal remote may work. Look for a higher end universal remote with a Source or Input button. Then test all of the codes for your TV brand. (Some codes may only enable parts of the remote functions; make sure you find a code that lets this button work.) The remotes that can be programmed with a USB connection to a computer are the easiest to set up for this situation. Please add a comment with the specific make and model of your TV; I'll try to find a source for an exact replacement remote. Cindy Wells (some really old TVs let you swap from AV1 to AV2 to channels by going up or down through all channels to reach a point where you could swap the inputs.)
2/3/2012 5:50:07 AM •
byD sign...
Answered
on Feb 03, 2012
I have a d:4742m 47
No pictures can be due to no 24vdc for the backlight, bad T-CON board (have backlghts but no pictures).
Please try below first:
First, look at the screen in darkened room to see if you can see any slight glow from the screen, if it does, then the problem can be the T-CON (not getting the 12vdc) or the main logic board not feeding the signals to the T-CON board.
if not, next place to check will be the power supply module, make sure it has 24vdc which is required by the backlight inverter to work, the reason for not having 24vdc can be from bad DC filter caps (leaking/bulging top, high ESR) or short circuits in the inverter board which will cause the 24vdc supply to go into shutdown mode, so you may have to disconnect the power cable that feed the inverter board to see if the 24vdc will work without the inverter board hookup, you will need to apply about 3~4 amp of load to the 24vdc to make sure it can handle that. There are fuses on the backlight inverter boards also. So there is some troubleshooting you will have to do to find out the causes of the problem you are having.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please post back what you find.
12/28/2010 5:17:24 AM •
byD sign...
Answered
on Dec 28, 2010
I need a new power
Most of the flat pannel tv have a standard D shaped removeable cord. all most all computer pc's use the same cord. they should all be three prong. unless you are not in the usa. Most people will have atleast one of them around. good luck.
8/30/2010 2:32:36 AM •
byD sign...
Answered
on Aug 30, 2010
What is the sky remote code for a cello model c20234f-led ?
Turn on your Sky Box and TV.
On your Sky Remote, press the TV button.
Simultaneously press the Select and Red buttons until the red LED on your remote blinks twice.
Enter one of the following 3-digit remote codes for Sky TV:
2274
2169
1874
1798
1872
1873
The light on the remote should flash twice. If it blinks only once, repeat the steps with the next code.
Press the Standby button on your remote. If your television turns off, press the Select button to save the setting.
Turn on the TV and press TV Guide; if the TV Guide list displays on the screen, the programming was successful.
Remember that there are multiple versions of Sky Remote Controls available, so ensure you have the most recent version. If you encounter any issues with the 3-digit codes, you can also try using a 4-digit code. Here's how:
Repeat steps 1 to 3.
Enter the 4-digit Sky remote code for your TV brand.
Press the Standby button. If your TV turns off, press Select to save your settings.
Check if the TV Guide displays successfully on the screen.
Sky TV Remote Control Codes
