Every few weeks, the bottom of he Fridge fills with water and Ice, requiring it to be removed manually. How is this remedied?
SOURCE: water in bottom of fridge
THE DRIAN HOLE IS CLOGGED ITS IN FREZZOR IN THE BACK BEHIND THE BACK PANEL BUT YOU CAN LOOK UNDER THE FRIDGE AND FIND THE OTHER END OF THE DRIAN HOSE BLOW AIR TROUGH IT TO CLEAN IT OUT MAKE SURE THE FRIDG IS OFF FOR A DAY, OPEN FREEZOR DOOR TO MELT ICE IN DRIAN HOLE AND HOSE AIR PRESSOR MAY NOT BLOW THE ICE BLOCKAGE OUT DEFROST FOR A DAY THEN IT WILL CLEAN UP NICE
SOURCE: layer of ice forming on bottom inside of freezer - Samsung fridge freezer
might have the temperature too high .. buy a freezer thermometer and place in freezer
SOURCE: Water dispenser inside fridge and ice maker in freezer part in bottom both quit working.
There can be many reasons for no water supply. Line feeding the refrigerator is clogged or blocked. The water control valve that turns water to ice maker and dispenser is defective or the water filter located inside your refrigerator is in need of change. I will be here to help you go through the steps. Let me know when you are ready, Thanks, Sea Breeze
SOURCE: samsung fridge model srs535nw service manual
Behind the white plastic section at the back of your freezer (4-6 screws to remove) there is a drain hole at the bottom. This will be frozen and prevent water from defrost from draining away - we have exactly the same problem. defrost the freezer and ensure this drain is no -longer frozen. I used hairdryer and warm water to clear. You may have a secondary problem of defrost cycle going wrong - the most common replaced part is R1098 or something like that a defrost sensor which is easy to replace by removing the top rear plastic section - 3-4 screws to remove and it simply pulls out as it is lightly clipped in. I was worried about breaking it but it came out with a bit of a tug. The defrost heating element is another part which can pack in. I'd replace the other part first and see how it goes.
