I want to lose weight and don't know which tea is better
SOURCE: sediment in my electric tea kettle
it is very hard to get rid off ass the sediment comes from the tap water untill you boil the water you dont see this sediment and take it for granted that the water is clean but as soon as you put it in a electric kettle this sediment builds up on the element then it brakes off and floats around in the kettle most new kettles have a filter near the spout so when you pour the water out it traps it in the filter then this can be removed and cleaned but the sediment floating in the kettle is hard to get out you can clean the element and descale it and then just keep pouring water in and out of kettle till its all out but it will soon build up again there are two ways to stop sediment one is filter all the water before putting in kettle but this can be slow process so not worth doing or the best sollution is buy a kettle that has a filter by the spout of the kettle and clean this regularly hope this is some help to you............................................
SOURCE: Cuisinart Perfect Tea Steeper model GB-TEA410 manual
yes i have Instruction Booklet for the Cuisinart Perfect Tea Steeper Model tea410. What did u need to know
SOURCE: how do you use loose tea to make tea in a pot?
You can use steel pot to make a Tea, do you know Loose tea is very simple to make.
If you will use steel pot that is easy to hold and keep.
