Does the radio play ? Are any other back lighting components not lighting ? Does the HVAC control panel light up ? You probably need new radio !
The second interior lighting group includes lamps which may be dimmed. This group may use a combination of vacuum fluorescent (VF) illumination, LED illumination and incandescent lamps.
When the ignition switch is turned to the RUN position, the radio VF display turns ON at maximum brightness. When the park lamps are ON, all incandescent and LED back lighting turn ON at the dimming level indicated by the instrument panel (I/P) dimmer switch. At the same time all VF displays dim to match the indicated dimming level. The panel dimmer switch potentiometer is an input to the body control module (BCM). When the driver selects a dimming setting by moving the I/P dimming switch potentiometer, all incandescent back lighting lamps are provided with a specific voltage. When the I/P dimmer switch is moved from MIN to MAX, all VF displays, as well as all incandescent back lighting respond from minimum intensity to maximum brightness in response to the I/P dimmer switch.
Most screens can be turned off for low battery usage. Check battery with tester or have it tested or replace battery and check menu and see if review screen is turned off. Rich
If the camera was dropped and cannot take pictures, then it is in need of professional repair, I believe.
Reviewing pictures already taken means that the memory and display on the back are ok. But, taking pictures involves mechanical issues that have been compromised, unfortunately.
That's normal for the D60. It works the same way SLRs have worked for half a century: you view and compose through the optical viewfinder, then snap the picture. The D60 lacks the Live View feature of more recent dSLRs; the LCD (not LED) display on the back is for menus, settings, and reviewing pictures after you've taken them. It is not for composing and framing your pictures.
This error code means there is an abnormality.
If the on-off door lock LED on a Whirlpool washer flashes rapidly at the same time as at least one other LED, then this means there is an abnormality.
Try first to reset the machine. You can press and hold the reset button for a couple of seconds, otherwise turn off the power completely (unplug it) for 5 mins.
Check the back of the cluster. Many have taken a real hard jolt after seting a wheelie down too hard. Could just be the connection there. As for the EFI light too many other probables.
my phone wont stay on and when it does come back on it shuts right back off. the LED light on the front keeps flashing red. ive taken the battery out and everything and nothing seems to work. help please!
