Hello Nicholas, it would be nice if you commented that audio signals are connected to your Soundbar, in this way I could find the possibility of failure, to find the best possible solution
I wait your answer
Greetings Franco Dosil
Hola Nicholas, seria bueno que comentes que se?ales de audio tienes conectado a tu Barra de Sonido, de esta manera podre buscar que posibilidad de falla, para buscar la mejor solucion posible
Espero tu respuesta
Saludos Franco Dosil
https://data2.manualslib.com/pdf5/110/10927/1092650-philips/hts8100.pdf?c627f1691eabddb18405d1975afcf790&take=binary
SOURCE: 75-822 cb that has extremely low audio output
Hello..if you can try to connect a external speaker or phones..if the volume is ok..than i think it is time to replace your internal speaker..pse tll me....good luck...Ron
SOURCE: Volume is too low, even then it is turn up to the max.
Have you looked at the menu on your cable or satellite box to see if there is a seperate volume control for the box?
Usually it is found under
Settings>>Audio>>STB Volume
SOURCE: How can I reset my Philips Soundbar system
You just remove batteries , unplug all cables, then put everything back together. This will reset the unit to factory settings.
SOURCE: Kenwood TS50 - Max volume gives very low audio while receiving
It sound like a bad reostat in the volume control. if its under warranty send unit back to kenwood and have them replace the volume control, and possible speaker involvement.
SOURCE: i have a wharfedale i bar 10 soundbar and if i
where did u buy your ibar from i have one and its broke need to no where you can buy them
Hi, did you figure it out? I'm having same issue.
Hello Barbara, it would be good if you commented that audio signals are connected to your Soundbar, in this way I could find the possibility of failure, to find the best possible solution
I wait your answer
Hola Barbara, seria bueno que comentes que se?ales de audio tienes conectado a tu Barra de Sonido, de esta manera podre buscar que posibilidad de falla, para buscar la mejor soluci?n posible
Espero tu respuesta
