20 Most Recent
Philips A5.600 Computer Speakers Questions & Answers
I would like a wiring diagram inorder to connect
I know this is coming awfully late for the original poster, but for the sake of others in the same situation here's the pin diagram for the Phillips 9-pin connector. (See the image in the comments section)And for those interested also the receiver data cable pinout.
Lost remote control
Replacements may be available at eBay. If not check with the Philips Company directly. The control is no doubt some place in your home. Look behind the seat cushions....lots of things fall down there. Who knows; you may even find that lost change to pay for a new remote!
Which remote can replace my old broken remote of the philips A5.600
Most remotes that do not work can be fixed--I would go that route first.To help you I need to know if only some buttons do not work or all etc.The remote if some work can be tested: most shops have a card that the remote is pointed at--buttons pressed and the tester beeps or flashes a light---this can also be done with some digital cameras where the screen will flash when remote pointed at it when on to see if only certain or all buttons on the remote are working.The remote sends a infrared signal and this can be seen.If only a few (usually adjacent buttons) do not work something got spilled onto remote and got inside---this can also be easy.Let me know as much as you can. (see make a comment button on this page)
I've got a PC amplifier
Yes, the amp will work just fine without it . Just that it will be a lot harder to control it, and only for the basic settings.
Unfortunately a direct replacement remote can be obtained only by ordering directly at them - very expensive, not worth the money. You should better get an universal remote - the ones from Philips or Logitech will work for sure.
I have a Philips Kitchen
The skipping problem you are experiencing may be related to the shaft that the laser assy rides on. It may need a little greasing with silicon grease, just a litte bit. Or it could be the spindle motor is wobbling as it turns. If you are a little tech savy, then you can order a new CD drive assy through Ebay and swap it out when it arrives. If you get this far you need to know how to remove the solder short on the new assy otherwise the new drive will not work.
Does aj300d/05 have a fuse
The Philips iPod dock model "AJ300D/05" is not responding when plugged in. To troubleshoot:
- Check the power source and ensure proper connection.
- If applicable, look for any blown fuses as a potential issue.
- Verify the dock connector for a secure connection with the device.
- Confirm device compatibility and consider using adapters if needed.
- Check the remote control and its batteries.
- Look for a reset function if available.
- Update any associated software.
- Inspect for physical damage.
If none of these steps resolve the issue, reach out to Philips customer support or a professional technician for further assistance or potential repair.
