SOURCE: steamer on Elna press electronic
if you go to... http://www.elnausa.com/ and under contact us they may be able to help you with a manual and if your press is working.
SOURCE: Passenger seat won't heat
Hi my name is Allen!
The most probable cause for your problem is the heating grid that is mounted on the set for heating it, it is under the seat cover, the light will act weird because it is not completing the circuit. Raise the seat cover and visually look at it, it should be burnt.
For further asistance you may reach me at FixYa!
SOURCE: Dash brake light flashes
check rear wheel sylinders for moister. an indicator for a leak. replace it then bleed brakes. refill resivore should be fine then. check front calipers also or leaking line.
SOURCE: I HAVE A 4 WAY SWITCH 1 MASTER AND 2 COMPANIONS
you should clean the remote control. some dust may affect the function of your remote control.
regards.. rated me rhanks
