SOURCE: 6 gallon proforce air compressor not building any pressure
You might have a broken valve. You'll need to pull the head apart. But make sure replacement parts are available first. Does this unit have an unloader valve on it ? That could also be your problem. You probably should check this first
SOURCE: proforce air compressor M#VPP0301104 w/a bad resistor
Resistor or capacitor , you can pick these up at a grainger or appliance store.
SOURCE: i need a part for VPP0200604 PRoforce air
that made by powermate which is out of business no part. you can check with pramc co which owens that division know. 800-445-2276
SOURCE: I broke the wheel on my Proforce (VPP0200604) air
The wheel kit has been discontinued so I would go to http://www.mastertoolrepair.com/advanced_search_result.php?keywords=wheel&x=23&y=9 and see if you can match one up.
