20 Most Recent Carrier 42QG24-C / 38QG24-C 24000 BTU SPLIT AIR CONDITIONER FOR 220 VOLTS ONLY Questions & Answers
check your over-flow bottle & radiator for coolant ( this is the usual round silver cap in front of engine compartment // says DO NOT OPEN WHEN HOT !!!!!!!!! ) if empty ,look for leaks or have pressure tested for leak ------------ also check to see if electric radiator is turning on when it reaches operating temperature , this fan will also run or cycle on & off with the air conditioning on....--- if not check under hood fuse // relay for this circuit......
Carrier Air... | Answered on Jun 07, 2011
Check for power out of the contactor...is the condenser fan running?? If so then the compressor should have power...could be the compressor capacitor...or a bad compressor.
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Carrier Air... | Answered on May 14, 2011
it's either an electrical problem or it has internal damage.
Carrier Air... | Answered on Mar 17, 2011
Your pressure switch may be malfunctioning or the start capacitor may be starting to fail.
Air Tools &... | Answered 2 days ago
Optimum pressure is 1.3-1.4 bar f you have the model Livia with the gauge.It is a problem with the switch that turns on the heaters.It is called a pressure stat switch and it sometimes gets salt/calcium deposit on it that prevents it from cutting of the electricity to the heater.Dangerous as if the vent gets blocked it can explode.Change or clean the switch in vinegar to remove salt/calcium deposits.
Air Tools &... | Answered on Jul 14, 2019
Fixya does not sell Black & Decker parts.
most check valves are the same as long as the thread is same size
Air Tools &... | Answered on Jul 12, 2019
Carrier 42QG24-C / 38QG24-C 24000 BTU SPLIT AIR CONDITIONER FOR 220 VOLTS ONLY Logo
1 questions posted
Top Carrier Air Tools & Compressors Experts
Tom Chichester
ray gallant
ray gallant
Marvin
Marvin
Are you a Carrier Air Tool and Compressor Expert? Answer questions, earn points and help others
View Most Popular
  • Carrier Air Tools & Compressors
Most Popular Question
heat exchanger replacement carrier
  • Air Tools & Compressors
