20 Most Recent Coleman Proforce 6 Gallon Air Compressor Questions & Answers
Hi I have a coleman
This compressor appears to be an obsolete model, and the parts diagram (https://mastertoolrepair.com/air-compressor-parts-vpp0200604-vp0200604-p-14827.html) does not show a part number for the fan blade. This means it was either a subcomponent of another assembly -- probably the pump unit itself -- or it is out of stock permanently. I'd suggest you take the old blade and fill the mounting hole with epoxy, then after it cures, drill a new hole and reinstall it. Otherwise, your compressor is likely "toast."
1/10/2018 2:31:10 PM • Coleman Proforce... • Answered on Jan 10, 2018
Over heating
OILESS COMPRESSORS WILL HEAT UP MORE THAN OIL FILLED COMPRESSORS,HOW EVER 2 THING'S.CHECK TO SEE THAT THE AIR INLET/FILTER IS NOT BLOCKED OR CLOGED AND MAKE SURE YOU BOUGHT ENOUGH COMPRESOR FOR YOUR USE.HOPE THIS HELP'S
7/5/2015 7:41:19 PM • Coleman Proforce... • Answered on Jul 05, 2015
I have the pro source air compressor, 10 gallon, 2
First if it's brand new I'd take it back to where you bought it. They have to sell you a product that works and anything you do to it will either void their responsibility or the company warranty. That said; if you have no leaks and assuming the hole you're talking about is the input side for the air filter and not the output side of the pump that should have a tube running into the tank stand pipe, it sounds like you may have one or more broken reed valves or bad ring(s) on the piston. Oil-less air pumps have one ring or wiper that does fail, oil-splash pumps have pistons like small engines with compression rings and an oil wiper. If they are run without oil the damage can be catastrophic. Not hard to fix but if you break the paint on the head bolts you void any warranty you have on the unit.
6/29/2013 12:45:37 PM • Coleman Proforce... • Answered on Jun 29, 2013
I need new carbon brushes for a 2 gallon proforce
Best guess is that you have other problems because they don't have brushes. whats it do?
4/8/2011 9:44:06 PM • Coleman Proforce... • Answered on Apr 08, 2011
Need piston rod for rep0200604 compressor
A search of your model number turns up a powermate compressor. Unfortunately the piston rod is not available as a seperate part, you have to order the entire pump/motor unit. The only place I could find it was at this link: http://www.ereplacementparts.com/powermate-vpp0200604-single-stage-oil-lubricated-air-compressor-parts-c-117046_117047_117049.html.
12/23/2010 7:38:46 PM • Coleman Proforce... • Answered on Dec 23, 2010
Air leaks at the turnoff knob
Hi, my name is John. Welcome to FixYa. Tk, replace the pressure switch. Thanks for choosing FixYa......John
11/25/2010 2:08:59 PM • Coleman Proforce... • Answered on Nov 25, 2010
0answers
I need a phone number
moz-screenshot-2.png888 895-4549
http://www.aircompressorsdirect.com/technical-support.php
good luck and don't forget to vote.
10/12/2010 9:57:56 PM • Coleman Proforce... • Answered on Oct 12, 2010
We have broken the oil cap and need a replacement.
You should be able to get the part at http://www.jackssmallengines.com/coleman_sanborn_parts.cfm Just put in the model number and follow the instructions. Jack's has parts for just about any small engine device and the prices are good.
Thanks for using FixYa and for the great rating.
hardrocko
9/15/2010 8:49:47 PM • Coleman Proforce... • Answered on Sep 15, 2010
My Proforce VPP200604 won't turn
I need to amend my last statement. Your problem is probably a burned out starting capacitor but it could also be a nonfunctional presure release valve. If your compressor start when there is no pressure but has these symptoms when there is pressure then the problem is the pressure relief valve rather than the starting capacitor.
7/19/2010 4:47:19 PM • Coleman Proforce... • Answered on Jul 19, 2010
My small pro force reaches a certain pressure and
hi, sounds like the safetyvalve is opening. there is a opening value on the valve, check this at moment of opening. if it opens at correct value, your pressure regulator is set to high. to lower this you have to open the regulator, (is the small case where the wires going in) and release the bold in the spring.(unplug first before opening, life parts) if the problem stays the same, make sure that the pressure out of the tank will reach the regulator. there is a small hole witch can be closed by rust or dirt. good luck, you can always aske for more options.
3/1/2010 6:39:44 PM • Coleman Proforce... • Answered on Mar 01, 2010
Compressor won't turn off automatically
adjust regulator. take off cover from regulator, release bolt or screw in the spring. if you do this while running watch out for electrical shock. if this dont work, check electrical part of regulator. can be stuck. watch pressure gauge not go over max. good luck.
2/11/2010 11:16:19 PM • Coleman Proforce... • Answered on Feb 11, 2010
Where can I get a new intake filter for my model
try e-bay thats where i got mine
11/24/2009 5:12:30 AM • Coleman Proforce... • Answered on Nov 24, 2009
Will not fill with air
Below is a link for parts to a Coleman compressor model #VPP0200604. Not positive but I think that is what you have.
However before you buy anything how do you know what the problem is? Is the motor running? If the problem is that it's just worn out you may find it difficult to get parts for rebuilding it. What you have is whats commonly referred to as a throw away pump. The second link show the pumps replacement cost, around $85.00. If you do manage to get rebuild parts for it they will cost at least that much.
You can get a Senco at Home Depot which is a couple grades up from yours for around $125.00.
Your compressor is really not worth the effort to rebuild it.
If on the other hand your compressors motor is not starting up please include any details in a response to this and I'll try and troubleshoot it for you.
Hope this helps.
http://www.mastertoolrepair.com/vpp0200604-vp0200604-p-14827.html
http://salestores.com/colema14.html
11/16/2009 10:28:25 PM • Coleman Proforce... • Answered on Nov 16, 2009
I need a part for VPP0200604 PRoforce air
that made by powermate which is out of business no part. you can check with pramc co which owens that division know. 800-445-2276
10/14/2009 9:16:13 PM • Coleman Proforce... • Answered on Oct 14, 2009
2answers
I need a capacitor 166-0138 it is obsolete. Can
here is a link to a web address specializing in obsolete components
http://www.obsoletefinder.com/obsoletecomponents.htm
10/12/2009 11:36:01 PM • Coleman Proforce... • Answered on Oct 12, 2009
Coleman Proforce 6 Gallon Air Compressor Logo
40 questions posted
Top Coleman Air Tools & Compressors Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Kardoc
Are you a Coleman Air Tool and Compressor Expert? Answer questions, earn points and help others
View Most Popular
  • Coleman Air Tools & Compressors
Most Popular Question
pro source air compressor 10 gallon 2
  • Air Tools & Compressors
