SOURCE: Change Windows XP language from Chinese to English
If the menus are all in Chinese then you will need to install an Enlgish version of Windows XP.
SOURCE: On a Cannon Powershot IXUS 86015 How do i change the language back to english?
Hey thaze,
According to the manufacturer you need to press the playback button, which looks like a triangle pointing to the right. Next you need to hold down the func. /set button, and press the menu button. Next you need to use the up/down arrows, or the right/left arrows to choose the desired language and then press the func. /set button. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
SOURCE: Ipod in chinese dont know how to switch back to english.
If you accidentally set iPod nano to use a language you don’t understand
You can reset the language.
1 Press and hold Menu until the main menu appears.
2 Choose the sixth menu item (Settings).
3 Choose the last menu item (Reset Settings).
4 Choose the first item (Reset) and select a language.
Other iPod nano settings, such as song repeat, are also reset.
Note: If you added or removed items from the iPod nano main menu (see “Adding or
Removing Items on the Main Menu” on page 11) the Settings menu item may be in a
different place. If you can’t find the Reset Settings menu item, you can restore
iPod nano to its original state and choose a language. See “Updating and Restoring
iPod Software” on page 69.
Good Luck and Please Rate FixYa!
Go to http://www.asus.com then select "Services" and click "Support". In the next window, click "Download". In the next window select "Product, Series & Models" in the selector boxes and click "Search". In the next window, select your Operating System. In the next window, click the Plus(+) sign next to manuals and scroll to the English Manual. When you read it, go to "System Recovery" if the left column and click. in the right column, You will see you need a USB external DVD drive. Reading further will tell you how to install the OS. If the system will allow you to change the language, it will be when you install a new OS.
SOURCE: How do I change language of my htc touch to english ??
by vising the given website www.htc.com pls furnish the proper model no of your mobile then u can automatically download the manual frm where u can know the procedure to channge language
