20 Most Recent
DXG Technology DXG-552 Digital Camera Questions & Answers
When I try to transfer
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
How do i find the cameras format function to make
hello Mr Minnie 999
#1 Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
# 2 Open up 'My Computer'. You should see it under the list of available drives.
# 3 Check its contents first to make sure that you have the right drive.
# 4 In 'My Computer', right-click on the drive and choose 'Format'.
# 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
# 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
My DXG model 552 is locked?
Try pulling the memory card out of camera too see if you can take a picture with out the memory card in place.
If you can do this the memory card is locked. Look at the memory card and find small swith on the side. Look for the lock symbol and be sure the switch is not in the locked position. Move the switch as needed.
Put the card back in and try it. This should solve your problem
Dxg 552
Have you formatted the card? Were you trying to put it in when the camera was ON? :D
Software for dxg552 camara
I am thinking that your new computer must be using Vista. You should consult with the camera manufacture for details conserning this.
If the camera is more than about 5 years old, the manufacture many not support it with Vista. We are seeing a lot of this type of thing.
Vista is having many compatibility issues with different softwares and drivers, and especialy for older devices.
Jerry G.
About web cam informiction
You cannot. You need the installation software to install it! Contact the manufacture or see your camera dealer for details about how to order a copy of the software.
Jerry G.
How to download to computer
You didn't specify the model of your DXG camera so I'm going to assume it uses a memory card of some type.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa (
http://picasa.google.com ).
Just pt in a neww
You must have pics on the internal memory. That's what the camera is telling you. You should format the internal memory with no card in the camera. Then, insert the card and it should work properly.
My open view is not showing any pictures but showing information about programs playing what might be the problem
Some steps you can try:
Check Picture Location:
Ensure that the pictures you want to view are in the same folder location. Sometimes, if the images are scattered across different folders, they may not appear correctly in the photo viewer.
Repair or Reset the Photo App (for Windows 11):
Go to Settings > Apps > Photo.
Click on Advanced options.
Choose either Repair or Reset to address any potential issues with the Photo app.
Enable Thumbnail Previews (for Windows 10):
Open File Explorer Options:
Type "file explorer options" in the Windows search bar and select the first result.
Switch to the View tab.
Ensure that the option "Always show icons, never thumbnails" is unchecked.
Click Apply and then OK to save the changes.
That is about all I can offer. If you repost, include brand and model.
4/19/2024 8:18:20 PM •
Cameras
Answered
on Apr 19, 2024
How do you turn on Digivue1.3? Has new batteries and used a while ago but pressing 2 button (Mode, Set) do nothing.
This is going to take patience and maybe the user guide. To turn on the Digivue 1.3, follow these steps:
Connect to Your PC:
Connect the standard USB cable (supplied) to a free USB socket on your PC.
The end of the USB cable should be connected to the socket on the back of the USB digidock.
Important: Do not connect any of the cabling provided with the Digivue before commencing the software installation.
Install DigiConnect Windows® Software:
Insert your Digivue into the docking station.
If you are connecting for the first time, a Red LED will display in the Activity Window of the Digivue.
Insert the CD provided into your optical disk drive. It will run automatically, and a dialog box will appear.
If the autorun feature is disabled on your system, browse to the disk using Windows® Explorer and double-click Setup.exe.
If you have a multilingual version of Digiconnect, you will be prompted for your language. Select from the list and click "Next."
Accept the terms in the License Agreement and proceed with the installation.
Choose the folder for software installation (default is the standard location for Windows® programs).
Click "Install" to begin the installation.
Leave the box labeled "Launch DigiConnect" ticked and click "Finish."
Wait for the Red LED:
Wait until a RED LED appears in the activity window of the Digivue.
You may now proceed with the next steps.
If you encounter any issues during this process, refer to the detailed instructions in the Digivue User Guide on page 9
4/1/2024 1:04:02 PM •
Cameras
Answered
on Apr 01, 2024
