Https://www.manualslib.com/manual/885094/Sharp-Ar-6020.html?page=111#manual
Are any of the indicators shown in the manual displayed?
Can you provide any more information using the Comment menu in FIXYA?
I think your copier exposer is not working properly or copy board is dirty. Clean all surface in optical mirror .
SOURCE: error code
Hi, H4 is a heater error. Try resetting it by the following; Enter #, interupt, Clear, interupt, display goes dead, enter 14 then print. That will clear the error code, however if you have a problem with the heater it will return. It is probably the thermal fuse has tripped, which is resetable by removing the fuser unit
Regards
Andy
SOURCE: sharp copier m550n
L4-03 is a lock of the fusing motor. It's likely you need to have the fuser rebuilt. You can try resetting the error by turning off the main power switch (located behind the front door under a little plastic cover) and back on. It's likely the error will come back. There's a cleaning screen on the lower fuser roller which gets gummed up with toner and sticks to the lower fuser roller causing it to seize and the motor not to be able to turn causing the L4-03.
SOURCE: Sharp AR-5320 Driver
Appreciate the direct "Ask Me". For Sharp AR5316/AR5320 drivers, pls click here. The drivers are for Windows 95, Windows 98, Windows ME, Windows NT, Windows 2000, Windows XP only.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
SOURCE: Sharp -COPIERS - AR-5316
@subscribe
Sharp does offer a linux driver, look for a cups driver.. Sharp offers drivers for mac, linux, hp output servers, as/400, windows etc... of course this varies on model number...
SOURCE: Sharp copier/printer AR-336
do the folowing to access service mode
enter,the folowing keys Program, Interupt,Clear,Interupt
once the service screen is displyed .enter the number 14 than press the enter key
