SOURCE: connecting bluetooth headset
You have to go through a process to pair the devices.
Firstly:
Make sure bluetooth is turned on on your laptop (varies for each model)
Make sure the headset is fully charged.
With the headset power off, press and hold
the Call button for 6 to 10 seconds until the
blue indicator light turns on and remains
steadily lit.
Then goto the bluetooth control panel and select "Look for Devices" or similar. Wait until the device has been found and when it asks for a passkey, enter 0000 and press okay.
see some more info at: http://tinyurl.com/2bz7hc
SOURCE: bluetooth ps3
MASTER RESET
At front of the receiver there is a button. Press it down
for 2 seconds. Next on the controller, hold the left 2 shoulder buttons down
WHILE re-inserting battery. Press the SQUARE button. Your controller should be working as normal.
SOURCE: Problem connecting headset via bluetooth on PC
You have to press the button to turn it on and hold the button pressed until it flashes red. Then you go in the control panel , bluetooth options, click it , and then go in the find devices options. When the computer finds the device you have to use the option to put your documentation key and use this default number 0000.
Conclude your installation.
SOURCE: Insignia NS-BTHDP ok with phone, pairs with PC but can't connect
Make sure the headphones are set as "default" under Control Panel>Hardware and Sound>Sound>Manage Audio Devices - same for microphone if you're using it for online speech.
SOURCE: Got a New Nokia BH-106 bluetooth Headset, i'm
i purchase new Nokia bluetooth headset BH-106 and i want to connect my laptop ( Dell INsprion N5010) plzz give some advise who to connect it.
