SOURCE: Tiller goes For./Rev. but wont drive forward with tines engaged
check the sher bolt on the tine to drive shaft. ill need model and ser number off the unit before i can go further with helping you thy changed them around a lot
SOURCE: I have a craftsman 19 in dual rotating tines, rear
I need to order a main-line pulling sprocket
SOURCE: Own a "Craftsman Rear Tine
Can you move the tines by hand???
They should turn by hand if you try to move them...if not then they are bound up by something...
either a bearing has gone bad, something has wrapped around them, or there is something stuck in there that will not let them turn...check for a rock stuck between one of the tines and the housing around them...
Get the tines moving freely and you will be okay again...
heatman101
