Home Security Logo
Dianne Couch Posted on Mar 23, 2019
I have a sisco save model # 115 combination and key do I have to pass 0 when I go left then right
Rob Barbour
Level 1:
New Friend:
  • Contributor 25 Answers
  • Posted on Apr 05, 2019
Rob Barbour
Contributor
Level 1:
New Friend:
Answers
25
Questions
0
Helped
21641
Points
25
Ignore the zero.....
Dial directly to the numbers.
Every time you Pass the number that is 1x so if it says
L4X 20
Then dial 4 times to 20... and so on....
Hope this helps, you can call a locksmith to walk you thru it too if they have time.
5 Related Answers
Anonymous
  • 80 Answers
  • Posted on Sep 07, 2009
SOURCE: LOST COMBINATION FOR MY SAFE SERIAL #156880S-R /MODEL 5054
http://www.sentrysafe.com
the instructions are located link above.
mj
Donivan Wise
  • 254 Answers
  • Posted on Jan 15, 2011
SOURCE: Besides the phone number or
Brinks safes are very reliable and secure, Unfortunately there is no way of recovering the the combination of the same without speaking with manufacture. Now you could do it the old fashion way that is to listen to clicks from the combination lock while moving the nob, However this takes alot of practice. The only the I would suggest to do is to speak with the Manufacture. I do appoligize once again and I hope you have better luck. Have a good day
Anonymous
  • 1961 Answers
  • Posted on Jan 29, 2011
SOURCE: i locked my safe numbers
I'm sorry if I can not give you the exact combination and I'm sure no one does. Because that is what Sentry Fire-Safe is all about, secrecy.
However, the best solution for your problem.... to be able to acquire the right combination for your safe.... is to call the attention of Sentry Safe Shop
You must call (800) 828-1438 for combination retrievals.
or send a notarized letter stating you are the owner of the safe, personal information, model and serial number of your safe and must indicate the method on how you will receive the combination.
See further details from this link
http://www.sentrysafeshop.com/Lost-Combination-Sentry-Safe-Combination-p/lost%20combination.htm
Please post back for any clarifications and let me know so I can help you further.
Thanks
Alpug
Anonymous
  • Posted on Apr 01, 2011
SOURCE: I lost my key and combination to my Brinks Home
ive lost my combination to lord safe how do i go about this
Bill Boyd
  • 53816 Answers
  • Posted on Apr 04, 2018
SOURCE: do you know the # to call for a sisco fire safe forgot combination
no
but you can get it from the sisco safe web page
How do we retrieve burial policy opening combination safe without combination but we have key?
other than a locksmith, all I can suggest is a half stick of dynamite.
2helpful
How do i unlock my safe with: Model number MSW 3110 Serial Number BK 706346 Dial Combination 23-93-59 Thank you. Dan.
3 Digit Combination Lock
31-10-31
  1. NOTE: If your safe DOES NOT have a key, skip Step 3.
  2. Turn the dial to zero.
  3. Insert your key and turn it until the plunger pops out.
  4. Turn the dial to the left (counterclockwise) three times to the first number of the combination (pass the first number of your combination two times, stopping on it the third time).
  5. Turn the dial to the right (clockwise) two times to the second number of the combination (pass your second number once, stopping on it the second time).
  6. Turn the dial to the left to the last number (stop the first time on your last number).
  7. Pull the handle down; the door should open.
3 Digit Combination Locks for Security Safes
31-10-31
  1. Turn the dial to zero.
  2. Turn the dial to the left (counterclockwise) three times to the first number of the combination (pass the first number of your combination two times, stopping on it the third time).
  3. Turn the dial to the right (clockwise) two times to the second number of the combination (pass your second number once, stopping on it the second time).
  4. Turn the dial to the left to the last number (stop the first time on your last number).
  5. Insert the key; turn right.
  6. Pull on the key while it's in the lock to open the door.
3 Digit Combination Locks for Gun Safes
31-10-31
  5. Pull the handle down; the door should open.
Electronic Locks
31-10-31
  1. Insert the tubular key into the lock to the left of the key pad.
  2. Turn the key all the way to the right until the plunger pops out.
  3. Press the five-digit factory code. The green Proceed light will come on.
  4. Pull the handle down; the door should open.
4 Digit Combination Lock
31-10-31-10
  2. Turn the dial to the left (counterclockwise) four times to the first number of the combination (pass the first number of your combination three times, stopping on it the fourth time).
  3. Turn the dial to the right (clockwise) three times to the second number of the combination (pass your second number twice, stopping on it the third time).
  4. Turn the dial to the left (counterclockwise) two times to the third number of the combination (pass the third number of your combination one time, stopping on it the second time).
  5. Turn the dial to the right to the last number (stop the first time on your last number).
  6. Pull the handle down; the door should open.
You can find more information about your Sentry Safe at www.SentrySafeShop.com
I cannot find a user manual at sentry.com for my model of safe.It is model SO409, serial #ARO99276. The combination is 21-96-64. I have started at (0) turned to left three times to 21 and the to left...
Try this combination exactly and let me know if it works.
First, turn the knob to the right a bunch of times to clear everything. Next, starting at 0, turn left and pass your first number twice, stopping on it the third time. Next, turning right, pass your second number once, stopping on it the second time. Finally, turning left, go straight to your third number and stop. Turn your lower handle to the left and pull.
Good Luck!
2helpful
Ihave brinks firesafe model#5059, serial#042589 . Ihave the keys of it,but forget combination number pl. help me how to set it.
1-800-223-8566 m-f pst 8-4
Call the number above, give them your model #, the serial number (located on the right side of the safe next to the model number), and your key code. They will provide you with the combination to your safe. your combination number will be provided to you immediately.
Also, you can try
Combinations consist of FOUR (4) positions (numbers).
BEFORE YOU START
Before you begin, please clear all settings by turning the dial CLOCKWISE (to the right)
three times. We also recommend to try the procedure with your safe door open first. Then
follow these steps:
TURNING SEQUENCE
1. Start the dial on 0 (zero).
2. Turn the dial to the RIGHT, passing your first combination number FOUR (4)
times and stopping at that number on the fifth time around.
3. Turn the dial to the LEFT, passing your second combination number TWO (2)
times and stopping at that number the third time around.
4. Turn the dial to the RIGHT, passing your third combination number ONE (1) time
and stopping at that number the second time around.
5. Turn the dial to the LEFT, to the last combination number and STOP.
6. Insert the key in the cylinder lock and turn RIGHT to open.
Your safe should now be opened.
Take care.
4helpful
2answers
Brinks fire resistant safe model 5059 instruction manual
Here is the turning sequence:
General Turning Sequence Instruction NOTE SAFE MODEL 5054/5055/5059/5080/5081/5084/5111/5190/5195/5575/5700/5702.
BEFORE YOU START
follow these steps:
TURNING SEQUENCE
24helpful
9answers
Brinks safe model # 5054
go to honeywellsafes.com apparently brinks was bought out
207helpful
16answers
To bad you dismantled. Here is the turning sequence:
BEFORE YOU START
follow these steps:
TURNING SEQUENCE
Top Home Security Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a Home Security Expert? Answer questions, earn points and help others
