Which is the actual temp
Http://www.turboairinc.com/index.php/tsr-49sd-7453.html
I hope this helps. Thanks. :)
SOURCE: temp
This reading is a default setting and it looks like the ambient temp sensor is either faulty or missing, it should be located in the front lower plastic panels under the front bumper. hope this is of some help and if the sensor is missing/damaged you will not be able to reset it
SOURCE: external temp reading is wrong... can it be reset?
i belive thats a default reading for that sensor replace it there cheep buy from dealer and locate it in front grill som times debris hit tese and mess them up simple repair probably only one screw holding it on
SOURCE: 1997 Chevy S10 A/C not cooling. Fan blows
sounds like the airbox doors are not working these are located behind the dash passengers side, a chiltons manual availible at most parts stores for around $25 will give you diagrams and steps to access this area if u need that help
SOURCE: temperature control sensor?
Sounds like a loose connection -38 is probably the open circuit position. Not sure where the sensor would be though.
SOURCE: Outside temp reading is locked at 53 degrees
bring back to dealer under warranty or call them
