SOURCE: Blocked filter in Fisher & Paykel washing machine top loader
Fisher & Paykel washers do not have lint filters inside the tubs as they are designed to drain away any debris from the wash during the drain cycle.
SOURCE: Fisher & Paykel GW612 Top Loading Washing
Hi there
That fault is the pump blocked error (no change in water level).
i have a quick and easy way to solve this problem.
first turn the machine off then tilt the machine back and lean it on something(a chair or wall), look underneath, in the top right hand corner of the plastic outer boul you will see a small pump motor it has a fan on it spin this fan and if it is hard to turn that means there is somthing stuck in the drain pump keep turning the fan and try to free whatever is stuck in the pump, then try the machine on spin again all goin well the object in the pump should come out with the drain water(doing this will not harm the machine) if the object is still stuck you will need to get the water out of the machine (bailing or siphioning will work) and tilt the machine back again and take the wires off the pump and there should be a white tab on the boul holding the pump on pull this tab and twist the pump anticlockwise about a quarter turn(you will need a few towels or a boul or bucket to catch the water) and it should come off exposing the blockage.
Hope this solves your Problem.
Nick
SOURCE: We have a Fisher & Paykel Smart Drive 9
Thank you to the gentleman who sent us the Manual. We now know that F & P has an automatic Lint Filter which is pretty useless !! Oh, for the old method of a physical filter you can clean...
SOURCE: fisher & paykel washing machine fault codes
I have a Fisher & Paykel GW609AU Smartdrive Excellence 6.5 Washing Machine that would start then stop then start then stop a few more times before eventually beeping.
I fixed it by bypassing(joined the white and yellow wire) the trip out switch which is located under the control module(one screw to remove).Now it Works.
SOURCE: Fisher & Paykel Washing Machine WL80T65CW1 Fault 9
sounds like a size error . when you changed the display did you size your machine to the new display module?did you get the re-size set of instructions with the new display board? ring up where you brought the display from and i"m sure they can help. if not reply back and i will guide you thru it.
