SOURCE: tefal 400 iron auto shut-off light stays on
TEFAL B.800
AUTO LIGHT ON,BUT NOT TEMP LIGHT.NOT HEATING UP.HAD BEEN USING BUT UNPLUGED WHILE I GOT MOE IRIONING.
SOURCE: hotpoint dish washer aquarius
I had the same problem with my Hotpoint Aquarius the eco and fast light flashing, it would go through the pre wash cycle and stop.
I cleaned the filters etc; and it still didn’t work.
I turned the machine off and unplugged it at the mains,
I drained all the water, turned the machine on the side and took the bottom off, I removed the drain pump off the bottom (this was held on with a single screw after taking the screw out slightly turn it to one side as its like a bayonet fit on a light bulb also remove the wire connection and a rubber drain pipe)
Once the pump was removed I could clearly see the impellor it was very tight and I couldn’t spin it after a closer examination I could see a foreign object jamming it I removed this with a pair of tweezers, replaced the pump and put it all back together and it now works perfectly.
I hope this can be of some help.
Peter.
SOURCE: Samsung 940bf-screen stays black
Your monitor is having a problem with the power supply.
Because of the small spaces in the monitor case heat builds up and
causes parts called capacitors to blow. If you can solder you should be
able to do the repair yourself. Go to our web page at:
www.ccl-la.com/badcaps.htm
and look at the pictures and repair guides. Open your monitor and look
for parts that look like the pictures. Replace any that you see and
your monitor should be back operational.Be sure to install the new
parts with the polarity stripe on the side
going the same direction as the bad ones came out. You will need to
replace them with a high quality part with high temp value (105c). If
you don't want to do the repair yourself we do offer a repair service.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
SOURCE: all pro heater runs for a couple of minutes.then
it only shuts down because of an overheating condition or the lack of fuel. if you have an ohm or multimeter, check the ohms on the fan and see if you have any resistance. If you do the fan is good but may still not be putting enough air across the heat exchanger to safely alloww the heater to run without causing a fire.
SOURCE: dish washer the clean
Hello & Welcome to FixYa
Flashing light is reset by pressing two buttons in sequence 3-4 times, to reset your dishwasher press these buttons in sequence:
High temp wash-heated dry-high temp wash-heated dry
Please get back to me if you have any other questions.
Kevin
