I dont know where is the problem
SOURCE: Canon IR3300 would not scan when use the
If it is not an iR2200i with the i, then u cant scan
SOURCE: how do i scan from canon iR3300
download the scan gear software & then u can use the scannerm
u can scan through adobe photoshop, ms office
SOURCE: error code e000733-0001
E733
0001 A fault is detected by the main controller PCB in the communication between
the DC controller PCB and the main controller PCB.
Main cause The connector has poor connection. The DC controller PCB is faulty.
Action
1. Connector, DC controller PCB
Is the connection between the connector J1015 on the main controller PCB
and the conductor J316 on the DC controlled PCB normal?
NO: Correct the connection.
YES: Replace the DC controller
SOURCE: canon ir3300 is giving me error code E6002-0003, h...
Turn off the copier using the power switch on the right. Turn it on again holding 1 and 9. You should see rectangles on the screen. Once this is finished the copier should be in download mode (If this process hangs or doesn't get started the disk will need to be replaced by a tech). Once you reach download mode you'll need a tech to flash the hard disk to get the copier going again. If this doesn't work, the hard disk will need to be replaced. In any case your hard disk is dying and will need to be replaced soon.
