SOURCE: file sharing between windows 2000 and XP
1) I believe that Windows XP is not setup for that by default,
you may need to install the old BETBUI service.
2) Also, if the 2000 machine has a login password installed,
it will NOT allow any other machine to browse it, without
logging in.
3) Password-less file sharing over NETBUI was available
on the consumer side of windows:
Windows 3.11 for Work groups
Windows 95, 98 and Millenium.
The professional versions of windows, built on NT
technology require a login:
Windows NT 4.0, Windows 2000, Windows XP,
and now Vista.
4) The best work around is to login to the 2000 machine when
it prompts you for a password, using your regular USER ID
and PASSWORD.
If the 2000 machine is not setup with a secure login,
just create a new account, ranking power user or higher.
5) Note that you only need to login over the network ONCE,
because windows XP can REMEMBER your password,
and login automatically the next time.
6) Make sure that the firewall (or A firewall) is not
blocking access to either machine, just disable the
firewalls for testing.
Similarly, if your LAN is behind a residential router, using
the router as a smart hub or switch, make sure that
the routers MAC address access blocking is disabled,
until you get everything setup and tested.
7) Finally if a PC is not visible in a work group, this does not
mean that it is not accessible. This is a Windows quirk.
You can try to access another computer by using the
default/administrative shares. These shares cannot be
disabled in XP, at least they will not stay disabled, as
they will restart during every reboot, whether you like it
or not.
This means that you can ALWAYS access all the drives
on another machine, whether you share them or not, unless
you take extreme measures in the local policies.
To access drive "E:" on a computer called "Henry" on a
machine in the same work-group,
open up windows explorer, and tyr the following into the
address line:
\\Henry\E$
This should access drive E:, after some delay, and possibly
a login prompt, even though drive is is NOT marked as
shared.
Down you just love windows ?!
Security by obscurity ?!
Microsoft is getting very good at hanging massive steel doors
on paper walls.
Hope this solves your problem, or gets around it.
Please rate my answers,
Martin
SOURCE: my yahoo messenger turn off
DOWNLOAD THE LATEST YAHOO IM UPDATE FOR YOUR OS.THEN RESET UP CAM/MIC IN YAHOO IM BOX.RICHARDM69
SOURCE: On two computers sitting side-by-side sharing one
Well the other computer sounds to be older or different than the other. Make sure the firewall is also not on super high.
SOURCE: Page not found error when clicking on a link on
The problem turned out to be the firewall in AVG. I set it to "allow all" for Facebook and now, no more problems. I have a windows firewall also, so it can be confusing how I have set them up, and which one is the problem. Thanks for your concern.
Happy New Year!
Judy
SOURCE: how do I import pictures
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive. Or you can use any photo cataloging program.
Yahoo messenger shares the internet connectivity to achieve telecommunication. Computers with stronger internetworking structures contribute towards attaining messenger experiences. First, the computer requires network cables that allow data sharing between several entities. Also, the computer requires enough memory capacity to sustain multimedia acquirable between messenger entities. Usually the computer requires sufficient spaces to attain the yahoo messenger as bundle of sot wares. Once the computer accommodate yahoo messenger, the internet connection capacity should allow files sharing beyond reading mail consisting of texts as the most minimal capacity to attain networking experiences. Second, yahoo messenger is capable of video conferencing requiring extensive capacity. First, wireless networks are available with broadband as capacity to accommodate huge media requiring sharing between devices. Cables media computers require high capacity wiring as a passage means to attaining media.
