I have had to replace the thermal fuse twice now and it still overheats. The airflow is good and the thermostat tests good. The fan is blowing well also. What else could it be?
SOURCE: Hotpoint NVL333EY Electric dryer blows thermal fuse
I had the same thing happen, I replaced the thermal cutoff and made sure no lint build up. It lasted a week then blew again. I then replaced it again and got to thinking why it would blow. I then took apart the exaust inside the dryer running fron the drum to the motor and right before the motor was a build up of lint ane particals that was almost like compressed sawdust which was blocking half of the line. I cleaned this out and it seemed to work much better.
SOURCE: Kenmore Elite HE3 front load dryer no power
Yes. Remove the kickplate and check the continuity of the thermal fuse located on the blower housing.
SOURCE: Kenmore Elite HE3 Dryer clothes not dry after cycle
it sounds like a clog in vent.if yours vents up thru roof you may need to have a chimney sweep come out and sweep vent.check and make sure the vent hose is net kinked or full of lint.
SOURCE: blown thermal fuse on Kenmore dryer
I need the serial# to assist you better.
Thank you for trust fixya.com
SOURCE: Whirlpool Cabrio model WED6200SW1 clothes dryer
There are two thermistors (thermal sensors) in this dryer; one is the outlet thermistor located on the blower housing and the other is the inlet thermistor located on the heating element housing as an integral part of the high-limit thermostat.
These thermistors are negative coefficient type and monitors the dryer temperature on their locations according to their resistance which varies inversely with the temperature. The resistance drops as the temperature rises and rises as temperature drops.
One or both of the thermistors has an open connection or high resistance which makes the electronic control board thinks that the dryer temperature is low no matter how high it is. The electronic control board then doesn't cycle the heater relay and continue to turn on the heating element. The dryer temperature continues to rise and this blows the thermal fuse.
Make sure the thermistors are connected snugly. Remember that loose or open connection means high (infinite) resistance which makes the electronic control thinks of low dryer temperature. Measure the resistance of each thermistor then refer to the tables below. Replace the thermistor if the resistance reading doesn't comply with the table.
Let
us know if you need further advice. Please accept
the solution should you find it helpful and informative. Accepting the
solution will not stop you from communicating with the expert. You can
still communicate with the expert should you need further advice
regarding the issue stated herein.
