Battery to charge newly filled, but only shows 5V - could this stop the charger from remaining on as it sees a "faulty" battery ? Thank you for your input!
You can get guide from many sites.. i know few
error codes/ fault codes, wiring diagrams, schematic diagrams, torque specs, engine info, switches functioning, assemble, disassemb ly, complete refurbish, repair, installation every single thing is covered
within seconds u can get the access and it's totally illustrative complete
SOURCE: battery not getting charged-power supply on ac power
hi thanks for using fixya!!
Is your laptop is brand new? Try to remove the battery. Then, try using your laptop and AC adapter without the battery, you will get the power supply directily from AC adapter. If it works properly, then its okay. Now, try to install back your battery then try to charge it. If not charging, perhaps you need to buy a new battery. However, I suggest you bring your laptop to a service technician to further check the error, before you purchase a new battery.
If you need further assistance, let me know!
SOURCE: battery will not charge on a dell d610 when plugged into outlet
I have seen this with faulty batteries.
Try changing the battery.
Also, check in the BIOS that the adapter you are using is recognised and shows a state of charging with the battery in.
SOURCE: Car Battery Charger - Repair
thats what i did on mine they blew when i hooked the cables up backwards (gotta watch that)
but i used 130 amp alt diodes from an old tractor alt i had
SOURCE: Samsung R40 laptop does not turn on.
You have a failing PMU on the motherboard it is like a sister bourd allowing the system to function nomatter what the situation this is fatal if not resolved i recommend a service center
Testimonial: "Thank you for this."
SPECYFIKACJA :
