When we use the Microwave + Hot Air(oven) function, after around 4-5 minutes it will throw the massage E02 on the screen, stop working and start to make "pip" sounds. The microwave is completely new.
SOURCE: oven and microwave combo
Your microwave is plugged into an outlet built into the top of the oven. This outlet has a "circuit breaker" that trips when using the self cleaning feature. This is a design flaw that Jenn-Air/Whirlpool refuses to acknowledge.
You just need to reset the breaker button that the microwave is plugged into. It's right next to the outlet.
Of course, getting to the reset button is your only challenge. You need to pull the microwave and oven out of the wall/cabinetry in order to get to it. The unit is heavy so you will need help. Or, call a certified repairman and they should be able to do this for you in 30 minutes or less so the service call should not run you more than @$85 if it is no longer under warranty.
I would also suggest you contact Jenn-Air to complain about this issue and seek reimbursement from them if necessary.
SOURCE: Microwave error code
EE4 means the line voltage is too high. Usually this is fixed by resetting the voltage selector on the back.
The voltage selector may not look like a switch, looking rather like a metal panel that has to be taken off and reoriented. There will be a label next to it indicating a voltage number.
EE2 actually means that the control circuit senses that magnetron number 2 is not running.
It doesn't necessarily mean a bad magnetron.
This can be due to a bad or misaligned door switch (common), a failed relay (#3) on the control panel, or a failed high voltage component such as transformer #2, capacitor #2, rectifier #2 or magnetron #2 or loose connections anywhere along the chain.
We have a similar model's service manual on our site. Please not that yours may be different! Part numbers will probably not match. But it will help with safety, disassembly, discharge and diagnosis.
It's here: http://www.microwavedisplay.com/r23gtf_sm.pdf
We're happy to help and we appreciate your thoughtful rating of our answer.
SOURCE: Sharp Covection Oven/Microwave stops after 1min on any setting
This 59-second stop failure is due to a problem in one of the damper-related components, most likely the switch, but it may also be the motor or the damper door.
The damper is a door inside that opens or closes depending on cooking mode. If the controller thinks that the door is not in the right position, it will shut down the cook cycle.
See the attached sample photo.
If you or someone you know wants to look into this, we have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We even have a video on our site that shows you how to safely & easily remove the control panel assembly to send it for service.
SOURCE: faulty microwave function on the SHARP R-957 model (900watt)
This
is a problem in one of the damper-related components, most likely the
The
If the controller senses that the door is not in the right position, it
Sharp models stop after
59 seconds.
photo for a typical damper assembly.
Info on ordering Sharp
UK parts / spares is here.
We're
happy to help you with free advice and we'd appreciate your
William E. Miller
[email protected]
SOURCE: loud pop and microwave doesn't heat anymore
I have a GE Profile Spacemaker model JVM3670WF001, purchased I think in 2003. Pop sound, no Heat. Light goes on, carousel goes around,
Repair or new microwave
