20 Most Recent Sharp R-1490 Microwave Oven Questions & Answers
manual
2answers
R-4H84 Sharp Carousel II microwave oven stoped working
A microwave can be dead for many reasons.
The fuse is normally located on the floor of the chassis behind the control panel or between the door switches.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
When checking thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
7/30/2013 1:28:14 AM • Sharp R-1490... • Answered on Jul 30, 2013
Sparking all the time I
That's a worn out waveguide port cover. You'll need to replace it.Years before the internet took off my Sharp R-9A20 had the same problem, I didn't have Amazon.com so I went to a shop that fixed vacuum cleaners, microwaves, etc. He had to grab a sheet of special cardboard and cut it to emulate the old one.Don't use oven cleaners that aren't microwave safe. They eat right through the metalic coating on the port cover that keeps the microwaves from reflecting back into the tube, I suspect that's what is up.
10/16/2012 3:33:50 AM • Sharp R-1490... • Answered on Oct 16, 2012
0answers
Microwave has power but makes grumbling noise and
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Basic Microwave Oven TroubleshootingTips
heatman101;'[p[
3/27/2011 6:08:04 PM • Sharp R-1490... • Answered on Mar 27, 2011
A plastic container with hidden piece of metal
The microwave oven is not safe to use, the fire has compromised the interior of the oven, if you run the microwave it will start to arc and eventually short out the magnetron, because the white enamel paint has been burned away. If you have holes in the ceiling there is danger of radiation leakage, for safety reasons the oven should be replaced.
2/23/2011 7:27:15 PM • Sharp R-1490... • Answered on Feb 23, 2011
Out of power. I checked power
Either the fuse is blown or the power supply is fried out. You can use a voltmeter to check
12/31/2010 6:57:10 PM • Sharp R-1490... • Answered on Dec 31, 2010
2answers
I NEED TO FIND OUT HOW TO TAKE THE DOOR OFF TO PUT
I just search the way the micowave was put together and I found out how to open the side on the door to get to the latch after I open the door I don,t think the latch is the problem the hook for the spring is broken so I think I will replace the door
12/10/2010 5:49:21 AM • Sharp R-1490... • Answered on Dec 10, 2010
0answers
Microwave was running fine. Suddenly
You have a failed high voltage transformer, magnetron, or high rectifier diode, or possibly both of the last two.
A loud buzz, hum, or groan is usually a shorted high voltage rectifier diode, but a sound like gurgling into an empty coffee mug is one symptom of a failed magnetron, and yet the mag can be bad without that sound.
The service manuals you need are here:
http://031d26d.namesecurehost.com/mwd/r1490_r1491_r1492_sm.pdf
http://031d26d.namesecurehost.com/mwd/r1480_r1481_r1482_sm.pdf
Here are some links you or someone you know can use for test help, but read their safety warnings first:
http://www.gallawa.com/microtech/diode.html
http://www.gallawa.com/microtech/mag_test.html
http://www.gallawa.com/microtech/xformer.html
You can order parts from Encompass here or you can call them toll-free at 866-779-5835.
10/2/2010 10:56:54 PM • Sharp R-1490... • Answered on Oct 02, 2010
Humming noise and does not heat and burning smell
This is happening due to either the magnetron, or the Power Diode, or both, is breaking down, under load, then the unit detects the fault condition, & then, for safety reasons, to avoid a fire or explosion, shuts down the system. You need to take it in to be looked at please obtain a "Quote" before proceeding with any work. This way you can decide to repair or replace.
7/17/2010 1:31:47 AM • Sharp R-1490... • Answered on Jul 17, 2010
Faceplate of door by lower L/H hinge
Front doors are attached inside the microwave at the top and bottom of the oven cavity. Top case has to come off using, likely, security torx screw drivers.
Remove the top hinge.
Remove the bottom hinge.
Door falls off.
Replace the front panel of the door.
Reinsert the lower hinge with the door, close and latch the door.
Holding the door firmly to the microwave, tighten the door hinge. Replace the top hinge.
(On some units, both hinges need to be installed at the same time. Use masking tape to hold the lower hinge - makes it easier.)
4/21/2010 12:38:41 AM • Sharp R-1490... • Answered on Apr 21, 2010
How do I remove an over the range Sharp R-1490?
Here's a link to the instructions for mounting the unit on the wall. Take a look at the section that shows 2 arms protruding out into the microwave2_bing.gif where the microwave is secured by a bolt. Have you removed these bolts? If so, the microwave should pull out. Here's the link to the guide:
http://www.microwavedisplay.com/r1490_r1600_r1750_r1870_r1871_r1872_r1874_hood_inst.pdf
3/7/2010 8:11:06 PM • Sharp R-1490... • Answered on Mar 07, 2010
My sharp carousel 401ck's digital numbers don't
We regularly repair these control units for customers nationwide by mail for $39.95 postpaid in about a week or so with a one-year guarantee.
Feel free to contact me directly (and please include your full model number from the tag in or on the unit) or visit our site.
William E. Miller
[email protected]
1/11/2010 11:08:55 AM • Sharp R-1490... • Answered on Jan 11, 2010
Noisy microwave not cooking
Is it making a louder than usual; buzz or hum when you try to cook?If so, I would suspect a shorted high voltage diode ore a bad magnetron.-.htmHere are some links you or someone you know can use for test help, but read their safety warnings first:
line-height:normal">mso-fareast-font-family:"Times New Roman"">http://www.microtechfactoryservice.com/diode.html
line-height:normal">mso-fareast-font-family:"Times New Roman""> http://www.microtechfactoryservice.com/mag_test.html
line-height:normal">mso-fareast-font-family:"Times New Roman""> http://www.microtechfactoryservice.com/xformer.html
Normal 0 false false false EN-US X-NONE X-NONE DefSemiHidden="true" DefQFormat="false" DefPriority="99" LatentStyleCount="267"> UnhideWhenUsed="false" QFormat="true" Name="Normal"/> UnhideWhenUsed="false" QFormat="true" Name="heading 1"/> UnhideWhenUsed="false" QFormat="true" Name="Title"/> UnhideWhenUsed="false" QFormat="true" Name="Subtitle"/> UnhideWhenUsed="false" QFormat="true" Name="Strong"/> UnhideWhenUsed="false" QFormat="true" Name="Emphasis"/> UnhideWhenUsed="false" Name="Table Grid"/> UnhideWhenUsed="false" QFormat="true" Name="No Spacing"/> UnhideWhenUsed="false" Name="Light Shading"/> UnhideWhenUsed="false" Name="Light List"/> UnhideWhenUsed="false" Name="Light Grid"/> UnhideWhenUsed="false" Name="Medium Shading 1"/> UnhideWhenUsed="false" Name="Medium Shading 2"/> UnhideWhenUsed="false" Name="Medium List 1"/> UnhideWhenUsed="false" Name="Medium List 2"/> UnhideWhenUsed="false" Name="Medium Grid 1"/> UnhideWhenUsed="false" Name="Medium Grid 2"/> UnhideWhenUsed="false" Name="Medium Grid 3"/> UnhideWhenUsed="false" Name="Dark List"/> UnhideWhenUsed="false" Name="Colorful Shading"/> UnhideWhenUsed="false" Name="Colorful List"/> UnhideWhenUsed="false" Name="Colorful Grid"/> UnhideWhenUsed="false" Name="Light Shading Accent 1"/> UnhideWhenUsed="false" Name="Light List Accent 1"/> UnhideWhenUsed="false" Name="Light Grid Accent 1"/> UnhideWhenUsed="false" Name="Medium Shading 1 Accent 1"/> UnhideWhenUsed="false" Name="Medium Shading 2 Accent 1"/> UnhideWhenUsed="false" Name="Medium List 1 Accent 1"/> UnhideWhenUsed="false" QFormat="true" Name="List Paragraph"/> UnhideWhenUsed="false" QFormat="true" Name="Quote"/> UnhideWhenUsed="false" QFormat="true" Name="Intense Quote"/> UnhideWhenUsed="false" Name="Medium List 2 Accent 1"/> UnhideWhenUsed="false" Name="Medium Grid 1 Accent 1"/> UnhideWhenUsed="false" Name="Medium Grid 2 Accent 1"/> UnhideWhenUsed="false" Name="Medium Grid 3 Accent 1"/> UnhideWhenUsed="false" Name="Dark List Accent 1"/> UnhideWhenUsed="false" Name="Colorful Shading Accent 1"/> UnhideWhenUsed="false" Name="Colorful List Accent 1"/> UnhideWhenUsed="false" Name="Colorful Grid Accent 1"/> UnhideWhenUsed="false" Name="Light Shading Accent 2"/> UnhideWhenUsed="false" Name="Light List Accent 2"/> UnhideWhenUsed="false" Name="Light Grid Accent 2"/> UnhideWhenUsed="false" Name="Medium Shading 1 Accent 2"/> UnhideWhenUsed="false" Name="Medium Shading 2 Accent 2"/> UnhideWhenUsed="false" Name="Medium List 1 Accent 2"/> UnhideWhenUsed="false" Name="Medium List 2 Accent 2"/> UnhideWhenUsed="false" Name="Medium Grid 1 Accent 2"/> UnhideWhenUsed="false" Name="Medium Grid 2 Accent 2"/> UnhideWhenUsed="false" Name="Medium Grid 3 Accent 2"/> UnhideWhenUsed="false" Name="Dark List Accent 2"/> UnhideWhenUsed="false" Name="Colorful Shading Accent 2"/> UnhideWhenUsed="false" Name="Colorful List Accent 2"/> UnhideWhenUsed="false" Name="Colorful Grid Accent 2"/> UnhideWhenUsed="false" Name="Light Shading Accent 3"/> UnhideWhenUsed="false" Name="Light List Accent 3"/> UnhideWhenUsed="false" Name="Light Grid Accent 3"/> UnhideWhenUsed="false" Name="Medium Shading 1 Accent 3"/> UnhideWhenUsed="false" Name="Medium Shading 2 Accent 3"/> UnhideWhenUsed="false" Name="Medium List 1 Accent 3"/> UnhideWhenUsed="false" Name="Medium List 2 Accent 3"/> UnhideWhenUsed="false" Name="Medium Grid 1 Accent 3"/> UnhideWhenUsed="false" Name="Medium Grid 2 Accent 3"/> UnhideWhenUsed="false" Name="Medium Grid 3 Accent 3"/> UnhideWhenUsed="false" Name="Dark List Accent 3"/> UnhideWhenUsed="false" Name="Colorful Shading Accent 3"/> UnhideWhenUsed="false" Name="Colorful List Accent 3"/> UnhideWhenUsed="false" Name="Colorful Grid Accent 3"/> UnhideWhenUsed="false" Name="Light Shading Accent 4"/> UnhideWhenUsed="false" Name="Light List Accent 4"/> UnhideWhenUsed="false" Name="Light Grid Accent 4"/> UnhideWhenUsed="false" Name="Medium Shading 1 Accent 4"/> UnhideWhenUsed="false" Name="Medium Shading 2 Accent 4"/> UnhideWhenUsed="false" Name="Medium List 1 Accent 4"/> UnhideWhenUsed="false" Name="Medium List 2 Accent 4"/> UnhideWhenUsed="false" Name="Medium Grid 1 Accent 4"/> UnhideWhenUsed="false" Name="Medium Grid 2 Accent 4"/> UnhideWhenUsed="false" Name="Medium Grid 3 Accent 4"/> UnhideWhenUsed="false" Name="Dark List Accent 4"/> UnhideWhenUsed="false" Name="Colorful Shading Accent 4"/> UnhideWhenUsed="false" Name="Colorful List Accent 4"/> UnhideWhenUsed="false" Name="Colorful Grid Accent 4"/> UnhideWhenUsed="false" Name="Light Shading Accent 5"/> UnhideWhenUsed="false" Name="Light List Accent 5"/> UnhideWhenUsed="false" Name="Light Grid Accent 5"/> UnhideWhenUsed="false" Name="Medium Shading 1 Accent 5"/> UnhideWhenUsed="false" Name="Medium Shading 2 Accent 5"/> UnhideWhenUsed="false" Name="Medium List 1 Accent 5"/> UnhideWhenUsed="false" Name="Medium List 2 Accent 5"/> UnhideWhenUsed="false" Name="Medium Grid 1 Accent 5"/> UnhideWhenUsed="false" Name="Medium Grid 2 Accent 5"/> UnhideWhenUsed="false" Name="Medium Grid 3 Accent 5"/> UnhideWhenUsed="false" Name="Dark List Accent 5"/> UnhideWhenUsed="false" Name="Colorful Shading Accent 5"/> UnhideWhenUsed="false" Name="Colorful List Accent 5"/> UnhideWhenUsed="false" Name="Colorful Grid Accent 5"/> UnhideWhenUsed="false" Name="Light Shading Accent 6"/> UnhideWhenUsed="false" Name="Light List Accent 6"/> UnhideWhenUsed="false" Name="Light Grid Accent 6"/> UnhideWhenUsed="false" Name="Medium Shading 1 Accent 6"/> UnhideWhenUsed="false" Name="Medium Shading 2 Accent 6"/> UnhideWhenUsed="false" Name="Medium List 1 Accent 6"/> UnhideWhenUsed="false" Name="Medium List 2 Accent 6"/> UnhideWhenUsed="false" Name="Medium Grid 1 Accent 6"/> UnhideWhenUsed="false" Name="Medium Grid 2 Accent 6"/> UnhideWhenUsed="false" Name="Medium Grid 3 Accent 6"/> UnhideWhenUsed="false" Name="Dark List Accent 6"/> UnhideWhenUsed="false" Name="Colorful Shading Accent 6"/> UnhideWhenUsed="false" Name="Colorful List Accent 6"/> UnhideWhenUsed="false" Name="Colorful Grid Accent 6"/> UnhideWhenUsed="false" QFormat="true" Name="Subtle Emphasis"/> UnhideWhenUsed="false" QFormat="true" Name="Intense Emphasis"/> UnhideWhenUsed="false" QFormat="true" Name="Subtle Reference"/> UnhideWhenUsed="false" QFormat="true" Name="Intense Reference"/> UnhideWhenUsed="false" QFormat="true" Name="Book Title"/> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin-top:0in; mso-para-margin-right:0in; mso-para-margin-bottom:10.0pt; mso-para-margin-left:0in; line-height:115%; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi;}We have the service manual and I have uploaded it to our site for you here.-.htmPlease reply back here if you still need help.We\'re happy to help and we appreciate your thoughtful rating of our answer.
4/13/2009 9:08:52 PM • Sharp R-1490... • Answered on Apr 13, 2009
I live in sarasota florida,where ican i go there
Getting the display repaired is an expensive repair, and may not be economically viable.
However, using the Sarasota Zip Code 34232 on the Sharp website, found:
SUNRAYS AND BABCOCK S
1621 DESOTO RD.
SARASOTA, FL 34234
(941) 358-9999
This is 4.6 mile(s) NORTH WEST from you.
APPLIANCE SERV OF FLORIDA
1629 W. UNIVERSITY PKWY
11/18/1991
SARASOTA, FL 34243
(941) 355-4545
This is 6.1 mile(s) NORTH WEST from you.
DISCOUNT RADIO PARTS
611 9TH STREET W.
BRADENTON, FL 34205
(941) 750-0531
This is 13.0 mile(s) NORTH WEST from you.
To search yourself, try http://www.sharpusa.com/products/FunctionGetService/1,1286,2,00.html
4/4/2009 9:14:42 AM • Sharp R-1490... • Answered on Apr 04, 2009
Strange rattle when microwaving
Chances are the blade assembly has come loose on the shaft of the internal cooling fan.
This can be solved with a couple of drops of super glue at the spot where the blade and shaft meet, then allow it to dry for several minutes.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Then you'll see the cooling fan.
Please let us know what you find.
12/25/2008 2:22:27 AM • Sharp R-1490... • Answered on Dec 25, 2008
R-1490 fan doesn't run or unit doesn't heat
That would be a defective secondary interlock (bottom door switch) or its mount.
We have the service manual for this model and have uploaded it to our site here to help you.
You will need the
free Acrobat Reader to view or print it in case you don't have it.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If you only need a switch, you can order a universal type here for $5 postpaid.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
12/17/2008 9:37:47 AM • Sharp R-1490... • Answered on Dec 17, 2008
Sharp R-1490 Microwave Oven Logo
38 questions posted
Top Sharp Microwave Ovens Experts
ZJ Limited
ZJ Limited
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
View Most Popular
  • Sharp Microwave Ovens
Most Popular Question
plastic container hidden piece metal
  • Microwave Ovens
