SOURCE: code to program ....
citizen tv 1004 1006 1008 1016 1038 1105 1132 1171 1174 1177 1191
samsung dvd 3154 3375 3399 3404
SOURCE: Jensen SC-570 Universal Remote
Try the auto code scan:
The Auto Code Scan feature allows you to set up your components without having to enter in code numbers. The Jensen will do the work for you! (It may take a few minutes to find your code using this method.)
Turn on the component that you want to set up.
Hold the component key down until the light comes on. The green light should come on after approximately 3 seconds.
Release the component key.
If you are programming the DVD or CD device press the "action" key. The red indicator light will come on.
Press "0" - "9" The green light will blink as codes are sent.
As soon as the remote turns your component off, press the "action" key. (You have 1 second in which to press the "action" key to save the code.) The component key lights will blink with an upward motion when a code has been successfully entered. The component is now programmed. To find that code, proceed to Code Readback.
If none of the codes turn your component off, return to step 2 and start over.
SOURCE: I need a Universal Remote Code for Coby DVD-288
http://esupport.sony.com/US/perl/model-remote.pl?mdl=RMV310
this a link to there web site for the remote as far as i see the remote will not work with the dvd player.
SOURCE: need universal remote codes for RCA Remote RCR312W
1.Go to the url below
http://www.rcaaccessories.com/rcaaccessories/RcaaccessoriesProductDetail.do?ACTION_TYPE_ID=ACTION_TYPE_PRODUCT_DETAIL&ACTION_CATEGORY_IDSTR_CATEGORY_UNIVERSAL_REMOTES&ACTION_PRODUCT_ID=RCR312W
2. Scroll down and select the "Support and Manuals" tab.
3. Click "Owner/User Manual" link
4. Click "Code List for RCR312W" link
