20 Most Recent Jensen JR300 Remote Control Questions & Answers
0298,0299,0291,0295. Try these codes. If you wish to get more details, check the sites linked here. Set-up code list, and Set-up procedure to many popular brand remote controls are given.
http://electrohelponline.blogspot.com/ http://remotesearch.blogspot.com/ Selecting the view option, either to Mosaic / Timeslide, can be selected by the drop-down list, by the top left of the display window, will make surf easy.
Jensen JR300... | Answered on Nov 05, 2013
0276,0782,0285,0281 Check these codes. If you wish to get more, check these links. http://electrohelponline.blogspot.com/
Jensen JR300... | Answered on Oct 08, 2013
Hello
Jensen remote has no setup code with Dynex tV. Avex-6 universal remote has setup code for Dynex TV. The code is 399
Jensen JR300... | Answered on Dec 30, 2012
press the power button on the jenson remote control. then press in this order up down left right 12679. Then press enter. If that doesnt work tough luck go hack it yourself
Jensen JR300... | Answered on Mar 31, 2011
here is your manual http://www.remotecodelist.com/remotes/jensen/JR300C.pdf
please vote for me if you found this info useful
Jensen JR300... | Answered on Mar 19, 2011
hi,
can you explain whats the problem with your remote at the time.
ok
Jensen JR300... | Answered on Jan 26, 2011
Hi
Here you will find everything about programming it
http://www.remotecentral.com/features/r-jr300.htm
Jensen JR300... | Answered on Nov 26, 2010
1) Try resetting the code search / programming
2) Try quickly tapping the OFF command key (opposed to holding it down for 2+ seconds)
3) Be sure there are fresh batteries in remote
The remote could possibly transmit a lower frequency setting for the 'OFF' state than it does for the 'ON' state. See if there's a setting for ON/OFF commands on the remotes 'Settings Menu'. You can also check the owners manua for your universal remote,l under 'POWER options ON/OFF. Make sure nothings blocking the IR sensor on the TV. Also bare in mind it may not be the remote but rather the TV's IR sensor.
However,
If still no results then send it back and obtain the original remote for the TV, which is always the best option.
http://tvtechwork.webs.com/
Jensen JR300... | Answered on Nov 08, 2010
HOW TO PROGRAM this remote is in the manual. You can download the manual instructions with codes for FREE at:
http://www.replacementremotes.com/Jensen-Advent-Manuals/Download-FREE-JR300-JR400-JR500-MANUAL-OPERATING-MANUAL.html
Jensen JR300... | Answered on Aug 05, 2010
i cant give u the exact one ull have togo thru these and find the one that works but here nthey are 0002 0502, 0906, 0112, 0512, 0520, 0115, 0701, 0402, 0805, 0407 one of these 4 digit codes should work just keep tryin them until u find the right one hope this helps
Jensen JR300... | Answered on Feb 25, 2010
If you don't have a Westinghouse remote the only codes that will work for a universal is the Sony codes, if all else fails you can buy an original remote for about $15 plus shipping and handling at parts@wde.com, just make sure you write the correct model of the TV and your contact information.
Jensen JR300... | Answered on Jan 25, 2010
Try this as all remote controls work the same when manual setting.
Here you go. This will work with most all universal remote controls. If you don't have the code do the following:
Automatic Programming
With automatic programming, the remote control tests all the codes available on the Code List and assigns the correct code for the selected device. Although this method can be more time-consuming, it eliminates the need to look up codes and enter them manually.
1. Turn off the device with which you want to use the remote control.
2. Press and hold the corresponding button on the remote control
(TV, VCR, SAT, DVD, CAB or AUD) until POWER INDICATOR illuminates. It should take a couple of seconds for the light to remain solid. The remote control is in programming mode.
3. Press and release power button. The POWER INDICATOR flashes once and stays on indicating the unit is in Power Scan mode.
4. Press CHANNEL up or CHANNEL down repeatedly until the device turns on.
5. When the device turns on, press OK to store the code.
Note:
• To exit without storing the code, press BACK.
• T he unit will search for the next code or the previous code if you press
CHANNEL up or CHANNEL down after the device turns on. (go slow you need to press OK when the TV turns on) if you mess up turn TV off and start over.
6. Press any other button. If the device responds, the remote control has been programmed. If the device does not respond, repeat steps 2-5.
Fill free to ask me questions about anything..........................
Jensen JR300... | Answered on Sep 28, 2009
I have a Jensen Universal Jer 323 remote. My TV brand is Sharp how do i program it and what code number do i use and also instruction for it.
Jensen JR300... | Answered on Jul 12, 2009
Link to codes for Jensen JR300 remote:
Codes for Magnavox:
Magnavox 0054, 1254, 0030, 0179, 0187
Jensen JR300... | Answered on Jul 03, 2009
I found that these websites should have all the codes and instructions for most remotes
http://www.xdiv.com/remotes/
or http://www.remote-codes.com/
if this helps please give a fixya rating
Jensen JR300... | Answered on May 27, 2009
I found that this website should have all the codes and instructions for most remotes
if this helps please give a fixya rating as thats how we get paid.
Jensen JR300 Remote Control Logo
47 questions posted
Top Jensen Televison & Video Experts
Jaime Hernandez
Are you a Jensen Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Jensen Televison & Video
Most Popular Question
programm
  • Televison & Video
