How to open it to change bag
Hi Kathy,
Click this you tube tutorial to see how they open the vacuum with the same model that you are looking for.
https://www.youtube.com/watch?v=yG29klTuWxc
SOURCE: dirt devil model 0914 cordless 15.6 volt
Go to: http://www.dirtdevil.com/CustomerService/Manuals/DirtDevilManual.aspx?ManID=b7c83c5d-3797-452a-bd73-4e0ed0ecc993
You can download a user manual from this link.
SOURCE: How do I change the bag on a dirt devil model 103?
On the open end of the bag that slips onto the vacume, there is a cloth "tab" sticking up from the band. Take hold of this tab and lift up while easily pulling back until you see the band about half way off the vacume. Now, you can take hold of the band and pull the bag the rest of the way off. You will notice that there is a "rib" in the middle of the band on the side that faces the vacume. That rib fits into the groove where the band goes on the vacume. When you install the bag put the band on this groove and work the band on around the housing. You can center the "tab" anywhere, just place it where you can get to it easy. The other parts you need are on the internet, I found them all including that rubber plug called the "attachment port" plug. The p/n for the replacement part is 3-201744-601. The original p/n is 3-501744-601 but you'll be better looking for the replacement part number. Good luck!
SOURCE: how do I replace the belt on a model 103 dirt devil hand vac?
HERE IS THE MANUAL will give you full instructions how to fit belt > http://dirtdevil.com/file/97/
