Televison & Video Logo
t
thokozan Posted on Mar 10, 2019
How to get started after resetting a hisense 10 phone
Unable to connect Hisense 65K390PAD to internet because, "Unfortunately, settings has stopped". Any suggestions?
Hi Cindy, unplug the TV for 10 minutes and try again
If you do not succeed, reset the TV to Factory Settings
I send you the link to download your Hisense manual
I hope you can solve the problem
Greetings Franco Dosil
Hola Cindy, desenchufa el televisor por 10 minutos e intenta nuevamente
Si no lo logras, resetea a Ajustes de Fabrica el televisor
Te envio el link para que descargues el manual de tu Hisense
Espero puedas solucionar el problema
Saludos Franco Dosil
https://etcpg3uvcgs41q4ci23mfssr-wpengine.netdna-ssl.com/wp-content/uploads/2015/11/65K390PAD_aus_m_en_man.pdf
https://etcpg3uvcgs41q4ci23mfssr-wpengine.netdna-ssl.com/wp-content/uploads/2015/11/65K390PAD_aus_m_en_qspg.pdf
2answers
HiSense F22. I forgot my parent access code, my daughter's phone is locked.
Are you sure you aren't the daughter trying to get around the code?
The onus is on your daughter to remember her access code. Your parental code allows you to make restrictions to the phone.
The only way to fix it is by doing a Factory Reset. Scrub it clean and start again.
https://www.google.com/search?q=hisense+f22+hard+reset
Jun 17, 2019 • Cell Phones
I've got a hisense phone from a friend and now am fiinding hard to set up it it say set up your hisense U601S
Try a complete factory reset and start over fresh format the phone and then factory reset
How to recover unlock pattern for hisense u962
You would have to hard rest the phone if u go to YouTube type how to hard reset hisense u962 there few what will show u how reset it ps but u will loose every thing off your phone as u resetting the phone
Nov 27, 2017 • Cell Phones
I have a Hisense 48H5. When I push the power button on the remote, the red light flashes and the "Hisense" name comes up on the screen. Within about 10 seconds, the tv shuts off and starts again.
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here. ..
Good day how to reset Hisense Infinity U989
not sure about that particular model, however, most hisense mobile phones have pretty much the same 'reset' steps.
1st, turn off the device.
then hold the volume up and Power buttons for a few seconds
...navigate through options using volume up/down button, and choose/confirm options with the Power button..
HISENSE H910 How to Hard Reset my phone HardReset info
Top Hisense Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
MrFixitSTTL
Are you a Hisense Televison and Video Expert? Answer questions, earn points and help others
