I tried changing all the set up options like ntsc to pal and other stuff and nothing
You need to connect the Video and Audio outputs from your camcorder or VHS player/recorder to the Honestech converter - Yellow is video, red and white audio. You play the tape back on the camcorder or VHS player/recorder and the video on the tape will play into the Honestech converter and will be digitised and sent via the USB connection to the PC and recorded on the PC. The Honestech cannot control your camcorder or VCR directly so you need to manually set it to play the tape.
SOURCE: Vertical addjustment for a DVD recorder
It should be inbuilt to switch on the vetical adjusment! or else you have to find another! 1
SOURCE: Pal to NTSC
If you bought a converter it would convert 25 frames a second to 29.97 or 30 frame 625 to 525 NTSC no adjustments and thats been that way for decades. You can rent a sony or Aiwa deck with legal converter on board and do this easy. So go and get a real converter!
