Computers & Internet Logo
Can't connect to the internet. Own a sharp Roku 50" tv. Network name is SSID. MAC address is 64:6E:69:5A:4B:7C
5 Related Answers
kakee
Michael Galve
  • 1269 Answers
  • Posted on Oct 14, 2008
SOURCE: attempting connection of a hp photosmart 7200 printer
What is the brand of your wireless router? Just make sure the SSID (signal's name) is configured on the wireless setting of your printer. They should have the same SSID configured. If the correct SSID is already configured on the printer's wireless settings, try to change the channel on your wireless router. Use channel 11. You can also try to do a power cycle. Turn off your wireless router and printer for about 1 minute. Power on router first, wait for the lights to stop blinking, then power on your printer.
rickyostrom
Ricky Ostrom
  • 274 Answers
  • Posted on Nov 24, 2008
SOURCE: I have a J6400 all
If your router is set not to broadcast or has encryption enabled, you will first have to program the printer by software throught a USB cable, or at the panel on the printer. The printer manual should explain how.
If you need a copy of the manual or other support, it's at this link. Just select your exact printer model and operating system first.
J6400 Printers Support
kakee
Michael Galve
  • 1269 Answers
  • Posted on Jan 06, 2009
SOURCE: XBOX 360 not connected to wireless connection on Linskys WAG54G2
You should enter the "Wireless MAC Address" of the XBOX and not just the "MAC Address". You can see it on the system info of the XBOX settings.
Anonymous
  • 59 Answers
  • Posted on May 17, 2009
SOURCE: Wireless Printer will not print wireless or connected
do you have the program disc if you do then inset it to the computer and hit restart installation and then follow the steps but make your you know your router name (SSID) first.
Anonymous
  • Posted on Mar 23, 2010
SOURCE: Scan to email gives server response error.
I've just discovered that Ricoh's built in software only works if your SMTP server sends out without picking up password or authentication.
Having same issue and it worked fine when it was behind corporate firewall with the same connection settings (IP address) as the SMTP server.
Once I changed web hosting - it won't recognize the SMTP server or any authentication methods. According to IKON (Ricoh support for the USA) - your SMTP server has to have "relay exception"
I keep on getting an unidentified connection via my Huawei WiFi router with MAC address BC:41:01:4C:CF:89. What does this mean and how do I stop it?
mac address is an unique network device equipment identifier.
How to stop it. Change encryption key when you add wpa or wep encryption to wi fi security on router. Added security - do not broadcast ssid and change it to something different.
All devices with wi fi will need to be changed to match wi fi encryption method and key and ssid name.
I need directions to connect internet to my sharp tv
Model number required for specific answer.
Generic steps are to access the menu and look for options labeled internet or Network.
Choose connection type either Wired or Wireless.
If Wireless look for the network name (SSID) for your network. Select that and enter the network password.
If you plug the TV directly into your router via an ethernet cable you should automatically connect.
Launch installed app to verify connectivity.
Arris gateway MG5235G/NA and am trying to get wireless roku box to connect. I'm getting the message: does your router block unknown MAC addresses? If so, add MAC address: CC:6D:AO:C2:CA:4B. Help?
Your gateway would not normally block unknown mac address on the lan side unless you have somebody extremely security conscious and specifically locked down the device - highly unlikely. Are you doing anything different than what is described in this procedure?
How to Hook Up Roku
How can I enter password in roku 3 I don't know how it connect and not work
I have created this document that will step you through the setup and also enter your password for your network. Hope this helps you.
Follow these steps to setup your Roku player 1. Connect to your TV
  • Use a HDMI cable. Connect one end to the HDMI port of the Roku player, and the other end to an available HDMI input on your TV.
  • Make note of the TV input used.
2. Power up key components
  • Open the battery compartment and carefully insert the provided batteries into the slots, following the correct battery orientation.
  • Power up the Roku player by connecting the provided power adapter to the Roku player and to an available wall outlet.
  • Turn on your TV and select the correct TV input.
3. Connect to your network
  • If you are using a wireless network, select "Wireless" as your network connection:
  • Select your network from the list of available networks.
  • Enter your wireless network password when prompted. (Note: passwords are case-sensitive)
  • If you are using an Ethernet wired connection, select "Wired (Ethernet)" as your network connection.
4. Complete guided setup
  • Get the latest software
  • Your Roku player will let you know if there is a software update available, and will restart after the update
    is complete.
  • Link your Roku player from any Internet browser
  • A link code should be displayed on the TV screen after restart
  • Using an Internet browser, follow the instructions to link your Roku player to a new or an existing Roku account.
Help for common setup mistakes and solutions
Symptom
Possible causes
Try these!
I don't see any picture on the TV
TV is OFF
Cable loose
Roku is OFF
Wrong TV input
Ensure TV is ON (it's more common than you think)
Check all connectors are snugly in place
Check power adapter is snugly connected, and wall outlet is working
Select the correct TV input
I can not connect to wireless network
Weak wireless signal
Wrong wireless name
Wrong wireless password Wireless name hidden
Move Roku player location (even a few inches may help)
Ensure correct network name selected
Ensure correct password entered
SSID can be hidden, use "Add Network" from wireless network screen
My remote does not work
Not in line of site
Batteries weak
Get closer and ensure there are no obstacles between your remote and the Roku player
Try a fresh set of batteries
Resolving wireless connectivity
If your Roku player isn't connecting to your wireless network, try the following:
Description
Do this
Tips
Repeat guided setup • •
Go to Settings>Network>Wireless•
If "Update connection" is available, select it to refresh your connection
If not, just select your wireless network from the list, enter your wireless password when prompted
If you were previously and just lost connection, you may not need to enter your password again
Passwords are case-sensitive
Restart the Roku player and • your wireless network
Unplug the power connector from • the back of the Roku player
Unplug the power connector from the back of your wireless router
Unplug the power connector from the back of your modem
Plug the power connector back into modem (wait a couple of minutes for it to fully boot)
Plug the power connector back into the wireless router (wait a couple of minutes for it to fully boot)
Plug the power connector back into your Roku player, and wait for the image on your TV
Follow repeat guided instructions above
Your wireless router and modem may be combined as one device
Factory reset the Roku player
From the Roku home screen, sele•ct Settings>Factory reset and follow the instructions
Note: You can also reset the Roku• player using the reset button. Find the reset button on your Roku player, press and hold for 15-20 seconds ( the front LED will rapidly blink a few times)
Factory reset should be used as the last resort, if all other steps failed to recover functionality
After a reset, you will need to relink your Roku player to your Roku account, and setup subscribed channels with username and password, if applicable
If you forgot your password, you can recover it here at this URL:
Forgot Password
A new password will be sent to the email account listed in your account. If you do not see the email, be sure to check your spam filter.
How can i connect my samsung tablet to my wireless internet?
I assume you are either unable to see your network listed or when you select your network from the list of active Wi-Fi Networks within range of you device and depending on security level no password or the Security Key you have doesn't work. First, make sure you have a few pieces of information: 1) The SSID or name of the network 2) The security type and password 3) If no DHCP service you'll need the ip address subnet and an available address for your device, ip address of the gateway/router, & ip address of the DNS servers. Usually the router provides DHCP and provides all of the addressing information.
Typically, you are provided the SSID and a security key or password. On your tablet open settings and turn Wi-Fi in necessary and look for your SSID in the list to the right. If your SSID is not shown verify the name, that the router is on and you are within range. Be aware of obstructions between you and the router. My Pool House is a virtual dead zone due to some electrical wiring on the wall it shares with the office. The router is less than 5 feet away, but the signal is unreliable. If everything is working and still no SSID on list, then it may be hidden. Simply, select Add Wi-Fi Network at the bottom and enter the SSID (Netgear987), security type (WPA OR WPA2 typically) and the password (PASSWORD maybe case sensitive). If it connects and fails to obtainan ip address or just drops it may indicate another layer of security that requires each device MAC ID is added to the list of authorized devices for that router. Your MAC ID is listed on the Settings_About Device_Status screen WiFi MAC Address: (F7:C7:AE:78:E6:FC). Sounds like a lot but usually verified SSID and password do the trick. Good Luck
I just purchaset a ruko 2 . when setting it up it recognizes the my network,when I put in the correct password it will not accept it , what do I do,it picks up wireless network but will not connect to...
Roku only connects to the wireless network. In the wireless section of your router setup use MAC filtering. Enter the mac address of the roku and enable mac filtering on the router. Save the selections and that should solve the connection problem.
I have an Sharp LC-60E920UN 240 1080 p and my my internet setup only shows interactive service and no other options. I am trying to configure my wirless network. Is this a programming problem
Get the MAC address from the TV and open your router setup page. In the wireless section enable MAC filtering. Enter the MAC address to the list save and exit. You should get a connection.
5helpful
2answers
How do I secure the router so that no one else can access it? model Dlink - DIR-615 Bruce
You should follow the next steps:
1. Log in via http://192.168.0.1
default username: Admin (use admin if it doesn't work) password: (leave it blank with no password) ----- 2. Go to setup tab ----> internet ----> internet connection wizard 2.1 CHANGE PASSWORD ! click next 2.2 choose time zone. 2.3 Configure your Internet Connection DHCP Connection (Dynamic IP Address) Choose this if your Internet connection automatically provides you with an IP Address.
2.4. press "clone your computer's MAC address" ; hostname: 'your computer name'
3. Go to setup tab ----> wireless settings ----> Wireless Network Setup Wizard (after this we're gonna do manual settings) 3.1 give your network a name= SSID 3.2.Automatically assign a network key (Recommended) and chose WAP or WAP2 3.3 Write down the network key Or do printscr and save this page.
You can leave it here, but it's better if you continue with the next step: -----
4. Go to setup tab ----> wireless settings ---->Manual Wireless Network Setup 4.1
Wireless Network Settings Enable Wireless : ALWAYS Wireless Network Name : (Also called the SSID) the name you gave in 3.1 802.11 Mode : chose "mixed 802.11n,g and b" Enable Auto Channel Scan : YES Wireless Channel : AUTO Transmission Rate : BEST (Mbit/s) Channel Width : AUTO 20/40 MHz Visibility Status : !!!Invisible!!! (so that no outsiders know your SSID except you)
4.2 Wireless Security Mode : WPA-Personal
4.3 WPA mode: WPA2 only Cipher type: AES Group key update interval : 3600 seconds
4.4 Pre-Shared Key : the one that you generated in 3.2.
Now you're all set, but you can't see your network from your PC (as you set it to be invisible in step 4.1). Now you'll have to set it up manually (the specific instructions will depend on your operating system) You'll need to enter the following date when you set it: your SSID name that you entered in 3.1 wireless security: WPA2 personal type: AES enter password that you've generated in 3.2 (or 4.4).
I dont know crouter configuration
Dear sir, Here's How:
  1. Choose a convenient location to begin installing your router such as an open floor space or table. This does not need to be the permanent location of the device. Particularly for wireless routers, you may find it necessary to re-position the unit after installing it as the cables / signals may not reach all areas needed. At the beginning, its better to choose a location where it's easiest to work with the router and worry about final placement later.
  2. Plug in the router's electrical power source, then turn on the router by pushing the power button.
  3. (Optional) Connect your Internet modem to the router. Most network modems connect via an Ethernet cable but USB connections are becoming increasingly common. The cable plugs into the router jack named "WAN" or "uplink" or "Internet." After connecting the cable, be sure to power cycle (turn off and turn back on) the modem to ensure the router recognizes it.
  4. Connect one computer to the router. Even if the router is a wireless model, connect this first computer to the router via a network cable. Using a cable during router installation ensures the maximum reliability of the equipment. Once a wireless router installation is complete, the computer can be changed over to a wireless connection if desired.
  5. Open the router's administration tool. From the computer connected to the router, first open your Web browser. Then enter the router's address for network administration in the Web address field and hit return to reach the router's home page.
    Many routers are reached by either the Web address "http://192.168.1.1" or "http://192.168.0.1" Consult your router's documentation to determine the exact address for your model. Note that you do not need a working Internet connection for this step.
  6. Log in to the router. The router's home page will ask you for a username and password. Both are provided in the router's documentation. You should change the router's password for security reasons, but do this after the installation is complete to avoid unnecessary complications during the basic setup.
  7. If you want your router to connect to the Internet, you must enter Internet connection information into that section of the router's configuration (exact location varies). If using DSL Internet, you may need to enter the PPPoE username and password. Likewise, if you have been issued a static IP address by your provider (you would need to have requested it), the static IP fields (including network mask and gateway) given to you by the provider must also must be set in the router.
  8. If you were using a primary computer or an older network router to connect to the Internet, your provider may require you to update the MAC address of the router with the MAC address of the device you were using previously. Read How to Change a MAC Address for a detailed description of this process.
  9. If this is a wireless router, change the network name (often called SSID). While the router comes to you with a network name set at the factory, you will never want to use this name on your network. Read How to Change the Router SSID for detailed instructions.
  10. Verify the network connection is working between your one computer and the router. To do this, you must confirmed that the computer has received IP address information from the router. See How to Find IP Addresses for a description of this process.
  11. (If applicable) Verify your one computer can connect to the Internet properly. Open your Web browser and visit a few Internet sites such as http://compnetworking.about.com/.
  12. Connect additional computers to the router as needed. If connecting wirelessly, ensure the network name (SSID) of each is computer matches that of the router.
  13. Finally, configure additional network security features as desired to guard your systems against Internet attackers. These WiFi Home Network Security Tips offer a good checklist to follow.
Tips:
  1. When connecting devices with network cables, be sure each end of the cable connects tightly. Loose cables are one of the most common sources of network setup problems.
What You Need:
  • A network router (wireless or wired)
  • Network adapters installed on all devices to be connected to the router
  • A working Internet modem (optional)
  • A Web browser installed at least one computer in the network
regards
murali
Wireless connection problem
Internet Setup
Internet Connection Type: Obtain an IP automatically
Host Name: linksys
Domain Name:
MTU: Enable Disabled
Speed & Duplex: 10 Mb Half
Local IP Address: 192.168.1.1
Subnet Mask: 255.255.255.0
Local DHCP Server: Enabled
Start IP Address: 192.168.1.
Number of Address: 50
DHCP Address Range: 192.168.1.100 ~ 149
Client Lease Time: 0 (0 means two day)
Static DNS 1:
Static DNS 2:
Static DNS 3:
WINS:
DDNS: Disabled
NAT: Enabled
Dynamic Routing: Disabled
Wireless: Enabled
Wireless Network Name(SSID): linksys
Wireless Channel: 6 - 2.442 GHZ7
Wireless SSID Broadcast: Enabled
Wireless Security: Disabled
Top Sharp Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Ngoro
john h
Are you a Sharp Computer and Internet Expert? Answer questions, earn points and help others
