SOURCE: blue grout spilled on tub while installing tile above the tub
Try 50:50 bleach and water with a green scrubber pad.
SOURCE: listello resin 3 by 12 : tile;white grout stuck on the tile
yes, you should seal all tile with a 3-5 year sealer. there are many brands to choose from. excess grout should be removed with a sponge and water before it dries. clean food splatters with any safe kitchen cleaner.
SOURCE: I have frameless shower doors, the bottom sill
if the glass actually contacts the tile you can go to the homedepot or similar place and buy some glass silicone sealer and just run a nice bead of caulk along the line, make sure you get clear silicone and let it thooroughly dry before you get it wet
SOURCE: Walk-in shower floor problem
They probably use wrong adhesive that is not hard yet and have tenedency under pressure to squeze out between grout lines. Yes they need to address the problem immediately.
SOURCE: I have crack in my shower floor concrete, would
There is a tile backer, kinda of like fiberglass mesh, I have also seen a waffle looking plastic, that will go down over the crack in the floor and will not effect the tile one bit. You just tile over everything, no mastic, no set under this stuff, no fasteners, just tile over it like a normal floor, and the best part is, no crack! Hope this helps.
Testimonial: "I am not done yet but it sounds like very good solution and I believe it will work Thanks."
