SOURCE: i bought this device but...
when you turn on the WEP200, you must continue to hold the button down until the blue light goes solid, that indicates pairing mode. Now, have your device search for it.
SOURCE: Windows Vista wont connect to these headphones
Try going to control panel->sounds->make the hands free audio the default.
SOURCE: Adding another external device to the sound system
yes you are right you can pick up an arc aux swich box from radio shack.
will do your job just fine.
thanks
and pleas rate this, if is of help to you.
SOURCE: Cannot receive bluetooth messages from other devices
go to media/device memory/and click receive using bluetooth ur problem will sol
SOURCE: aux cable snapped of inside external Audio port (AUX)
I have a 2007 CRV which had the same issue. I fixed this by:
- first removing the AUX port cover by carefully prying it up from both the rear-facing and front-facing edges. Once done, this exposes the AUX port mechanism itself.
- Using some needlenose plyers, I pulled out the AUX port component. It simply slides out.
- The trick now is to PUSH the broken piece out of the inside of the port. To do this, I first removed the "cover" that is covering the end of the port (opposite from the opening to the port). Be very careful with this step as you don't want to break the cover. It's very thin plastic.
- Once this cover is removed, I used a pin to push the piece that was lodged inside back out of the opening.
Reassembly was the opposite of this and was quick.
Hope that helps.
- Dave
Anything that has a headphone output can be adapted to feed an RCA cable pair for standard stereo to any audio device with a standard RCA input. Get a cable like the one described here:
http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10218&cs_id=1021804&p_id=665&seq=1&format=2
and connect it into any available analog input EXCEPT "Phono". Turn the MP3 player volume up.
Don
