There is some here but you need check spec
https://www.ebay.co.uk/sch/i.html?_from=R40&_trksid=m570.l1313&_nkw=Craftsman+table+saw+bevel+gears&_sacat=0
SOURCE: old craftsman table saw parts?
most sears stores have a dept. that refurbishes and sells these tools. if it can be had, they can help.
SOURCE: ingersoll rand g2 angle grinder exploded parts
Follow this link: http://www.irtechpubs.com/ir_pdfs/Tools/Finishing%20-%20Surface%20Prep/Air%20Grinders/04581237_ed5.pdf
On page 5 of this publication you will find 2 sets of bevel gear and pinions. You need to know which model grinder you have in order to get the right set. The different models are G2E, G2A, and G2L. On page 4 you will see the diagram for the right angle. You may be able to match up by sight which one you have. If you have the A or L you need to know the rpms of your model to get the right set.
SOURCE: parts for delta table saw model 36560c
go to Dewaltservicenet.com and type in model 36-560 exactly as I did and you can download a breakdown for this tool. The motor parts are on page 2 of the breakdown. Good luck and if I have helped you with your uestion qould you please rate this response accordingly. Thank you.
SOURCE: I have a craftsman table
Maybe you could try using the outline of the regular insert to cut a new insert out of a piece of polycarbonate (lexan) or ABS plastic. The clips that hold my dado insert barely hold it in place on mine, and I've seen other saws that use plastic.
