My LG smart TV (60UH6035-UC) keeps dropping our streaming movies on Netflix. Do I need to replace the network card inside the TV? I've already replaced our router and modem.
moved you out of computers, its not.
why just do Netflix, there are like 1000 streaming sources online, now, try more, like vudu, hulu, amazon, or 1000 of free ones. endless. to try, in the LG app screen for players, see em?
did you speed test your unstated ISP connections?
did you try the TV using hard wired to router with ethernet cable.?
use wifi test last, wifi is problematic.
if wifi tv is far from router it will be slow.
if wifi is overloaded in your HOOD , then it will be slow.
own a PC, try it yet, connected wifi and for sure ethernet
see it or runs Netflix and say 5 others ok ?
run Inssider.exe program see of wifi is jammed up?
not once did you say wifi, and I bet it is.
we have a gigalan , ethernet jack in every room here.
I pulled all land line cables and switch them all to ethernet
so now if wifi goes NUTS, wired works.
btw, wired not one error in 2 years, not even that pesky buffering error, on Netflix.
gee even NEflix has speed test to see if HD mode even works.
for you.
if others in your home are tying up wifi gee, there you go.
wifi is shared resource,
good luck
