Http://media.channelblade.com/EProWebsiteMedia/3506/Jabsco%20Twist%20n%20Lock%20Manual%20Toilets.pdf
the above is the link to the operators and installation manual see pages 3 and 4 this tells you how to install the inlet pipe so just reverse for removal
SOURCE: Water disappears to below the bowl inlet and stop.
adjust the float up to make water deeper....make sure no obstructions around the flapper....flapper needs to rest tight to bottom of inside the tank..flapper is the rubber peice that lifts when you push handle
Testimonial: "Thanks. Rubber on the flapper was torn. Hareware replaced the flapper. It work well now. Ciao"
SOURCE: Hi, please help i recently
Hi
I don't specifically know your model of marine toilet but with my Baby Blake I have known the joker valve turn itself inside out (I think due to someone forgetting to open one of the seacocks) which meant that very little would pass out through it.
