SOURCE: Dryer runs for 5 minutes then stops
look in the vent line for a small disk shaped overload with two wires coming out of it. it may be bad. also check for a lint build-up in the exhaust line out of the blower. check the damper outlet going out of the house for a build-up of lint.
SOURCE: Kenmore 80 series dryer stoping after running for 10 to 15 minute
Start any cycle. Dryer runs for 10 to 15 minutes, then stops before cycle is complete. Start again, stops again in 10 to 15 minutes.
SOURCE: GE Top load washing machine stop and stars during spin cycle
I had the same problem. The machine will do the washing cycle. At the start of the spin cycle it would start turning with a lot of clicking sounds and then would stop spinning. The water pump would continue working without problem. The motor tries to start again in about three minutes, however, repeats the same behavior. I have a reasonable mechanical and electrical knowledge. I was sure that the overload protection switch of the motor was tripping. I opened up my machine---a GE super capacity top loading machine. Took off the belt and turned the transmission pulley. It turned easily in both directions (washing and spinning). Hence, the transmission was good. Next, I checked any water accumulation in the spin tub. If the water is not drained properly before the spin cycle, it would overload the motor. There was no water clogged in the spin tub. Finally, I dismantled the electric motor. There was a clutch assembly underneath the motor pulley. I dismantled it and found the clutch very dirty with some grease that had turned sticky. I cleaned the assembly thoroughly with alcohol and assembled back the machine. The machine is running perfect after that. Conclusion: The clutch assembly was mis-functioning. Reason: When the spin cycle starts, the spin tub is very heavy and cannot achieve the full speed quickly. On the other hand, electric motors must get to their running speed fairly quickly or else overheating of motor would happen. A proper functioning clutch allows the motor to run at their optimal speed while transferring enough torque to the spin tub to slowly speed up the tub to its fullest. In my case, the clutch was sticky, thus overloading the motor which would trip as it overheats.
If you just put the fan blade back on, it will almost certainly fall off again.
The best bet is to slightly rough up the contact area of the shaft with sandpaper and use a little super glue to hold the blade assembly on the shaft, and let it set a few minutes before using it.
I always recommend that you use the hood vent exhaust fan when cooking on the stove top to keep heat, steam, and
grease out of the controls.
There
should be a "mini-manual" (tech sheet) hidden inside the unit
behind the
control panel or hidden on the left side behind the grille, which is
very helpful when troubleshooting, testing, and locating components.
At
our Web site, we have a video
available showing how to remove a typical
over the range control panel assembly in under 5 minutes.
You can find
helpful exploded view diagrams and order parts by entering your full
model number from the tag on the oven here.
Feel free to contact me directly (and please remind me of your
full model number from the tag on the unit) for more information & help.
We're
happy to help you with free advice and we'd appreciate your thoughtful
rating of our answer.
William E. Miller, AS-EET
[email protected]
http://www.microwavedisplay.com
SOURCE: dryer runs then stops after short periods (5-10 mins)
THere maybe a thermal limit sensor gone bad. Keeps the dryer from over-heating. Located behind rear panel on most and mounted on the heat tube. Verify with volt/ohm meter if possible
