SOURCE: Remote volume control for Sharp Aquos 42inch LCD not working
User 'rapolley' is absolutely right. One can cycle through the functions to access different options, ie. 'TV', 'Audio', 'DVD', etc. I stumbled upon this solution when I thought my 'Menu' button wasn't working. All I had to do is cycle through the 'Functions' and choose 'Menu' once I get to 'TV'. Thanks!
SOURCE: Program Comcast remote to operate Samsung 46"LCD
The answer depends whether its a Comcast DVR Remote or a regular one. The DVR codes are 4 digit -- the others are 5 digit. I got 0060 to work for my DVR remote.
0180, 0171, 0000 if your remote has a GREY ok/select button on it,
20675, 20821, 20000, 20593, 21593 if your remote has a RED ok/select button on it
SOURCE: looking for remote codes for vizio sound bar and
I have a vizio universal remote and the code that works the vizio sound bar is the first one listed under audio/vizio 0660
SOURCE: I HAVE A VIZIO SOUND
Hello, Daniel Busa with Dish Network's customer service try these steps if the remote will program this will do it
After much research, here is a
step-by-step for getting your Vizio Soundbar to work with the Comcast remote
using EFC codes (mine is the newer charcoal grey one, works great!)
Aux - Setup (2 blinks) - 11144
(2 blinks)
Aux - Setup (2 blinks) - 994 -
Setup - 00169 - Vol Up - Should get 2 blinks
Setup - 00168 - Vol Down - Should get 2 blinks
Setup - 00037 - Mute - Should get 2 blinks
Setup - 00165 - Power - Should get 2 blinks
Setup - 00164 - Input - Should get 2 blinks
These are optional, I didn't use
them:
Setup - 00036 - <button to use for TVOL> - Should get 2 blinks
Setup - 00101 - <button to use for TSHD> - Should get 2 blinks
Then set the volume control on
the remote and other settings according to the Remote's manual.
ENJOY!! Hope this helps someone...
