SOURCE: front screen only displays upside down Verizon logo....
Sounds like you should take it to have it looked at. Theres something up. The verizon thing only appears when the phone is opened so there must be something out of place in it so your phone can't read when it's closed. So I really can't help you there. To set the phone calls to answer automatically go to "menu" then "call settings" under "settings & tools". Now go to "in-call setup", then "answer options" and under there you'll find the choice to change it to open to answer. Hope this helped!
SOURCE: When I turn on my printer I get the message Error Press OK
You have to refit the micropump gear, this is happening because this gear should be out of its place. It's on the left side of your printer. I.ve just solved the same problem.
SOURCE: akai lct 2701td comes on then shuts down
Hi
You have power supply problem. Please go to ebay and buy cheaper price:
AKAI LCT2701AD POWER SUUPLY MLT166A
Thanks
GEORGE
SOURCE: Printer cycles on and off continuously
make sure that the switch is properly pressed on and it pops out again.
SOURCE: Good morning, I was given
I have exactly same problem with my brand new tomtom 540tm. it is in "sleep mode' but how to wake it up?
