It was purchased from good will and there isnt instructions. I put some water in it plugged it in nothings happening. there's no light to indicate that it's on either. Wondering if there's an extra step im missing?
Ignore all the sarcastic answers from people who are just negative @
It's not 'working because you're adding water only. It was supposed to come with a little tiny cup the smaller part is to be filled with salt in the larger part with water both are to be added into the machine and it will steam wonderfully and yes it does take out the things but do not lay it down when you're doing it or water will spill out on it and the salt can cause some staining which is again easily removed by wedding it down a little bit. However I lost my little cup and I am currently looking for the correct amount of salt to add I suggest writing emson itself which is what I'm going to do I wish you well
I am going to say I feel you purchased some garbage. There has to be a reason why the owner wanted to get rid if it. You cannot even question the former owner.
Testimonial: "Yes I feel the same. Sigh ??"
SOURCE: hello I was wondering where
FIRST DON'T EVER PUT WATER INTO YOUR ENGINE OR ANY OF ITS COMPONENTS. What you looking at is the Coolant resivour and your low. buy some 50/50 prediluted coolant and fill to the COLD line if the engine is cold, HOT line if you just turned your car off. Also wait until your engine cools and check your Radiator to see if you have enough coolant. If not, fill coolant to the opening neck, SLOWLY squeeze the top radiator hose until the coolant starts to almost spill out. top off to the top of the neck again and run your engine for 15 minutes and then allow to cool and check the level again.
SOURCE: My 4 wheel drive won't engage. Was working fine
YES THERE IS A FUSE. OWNERS MANUAL SHOULD TELL YOU WHAT FUSE *** IS. OR SOMETIMES IT IS JUST FASTER TO TEST THEM ALL. THE SWITCH ON DASH COULD BE PROBLEM. BEST THING TO DO IS HAVE A SHOP SCAN IT. THAT IS THE ONLY WAT TO BE SURE. THANKS MOTOR62500....
SOURCE: My fuse panel diagram is missing from my 1993
i have a 1995 fleetwood brougham and when you open the doors inside lights dont work neather does any of the in side light work with doors closed even the ones on the mirror
