SOURCE: Simrad Autopilot won't turn on
Try and turn on the unit at the J300-40 pcb by using a test light one end to gnd and going to the ap35 interconnect and touch the test light to each pin or until you hear the unit start up.
SOURCE: No sound via TV when PC connected
1. Ensure the TV is set to "home" mode in the user menu. If set to "Shop" it will not retain audio settings change
2. verify that the Audio out from the PC is working. Use a set of headphones just to verify
3. Triple check that you have the audio input assigned to the correct HDMI input
4. after doing these if it still doesn't work, I would suspect the Software update had a side affect that phillips is not aware of. Since this function would probably be missed by Phillips software testers, it is highly likely that this is possible. Contact phillips and let them troubleshoot the problem with you. Let them know it happed after you did the update also and let them know that you have verified the audio out from the PC.
SOURCE: Proper wiring from NMEA
I want to interface my Garmin 182c GPS with my B&G Hydra 330 gages. Both support NMEA 0183. How do I do this?
SOURCE: I have a Philips GPS Dantronik Navigater MK9 an
I connected my ICom using the NMEA in. I had the leads reversed first time, moved them around and worked. This was a connection from Furono to iCom but should be much the same
SOURCE: I have a Simrad CP33
Here is a link to the operation manual of the GPS plotter in PDF, it is a large file (3.25MB) so allow time for it to download.
http://www.busse-yachtshop.de/pdf/simrad-cp33.pdf
