20 Most Recent
Nokia 6300 Cell Phone Questions & Answers
My pin was blocked and i nid my puk code and pin..
You need to call your Cellphone network provider. The operator will provide the correct PUK code according t to your number.
Hope this initial info/ idea helps. Let me know for further instructions.
Thank you for using fixya.
Nokia 6300 music player wont play from my memory
Hello i hope u 'll be fine.... thanks for using
fixya.
This problem is usually occur when music player don't load data of memory card itself
- First of all turn off your cell insert your memory card carefully again
- Turn on your cell, when it 'll be on, open your music player it 'll take some time to refresh
- Now do in the options of music player
- Second option 'll be music library open it
- Go down there 'll be a last option Update Library, it 'll take some time and hope it 'll load all your music and all music files 'll show in track list.
Enjoy
I hope
this solution will work and helpful 4 u. Best of
luck
Please do rate if if it is helpful
THANKS
WHAT IS A2DP PTS MODE
I HAVE A GFIVE E 71 PHONE I AM NOT ABLE TO USE BOTH SIMS INCOMING FACILITY AT SAME TIME , THE ERROR MESSAGE WHICH IT GIVES IS " DISABLE SWITCH MODE", CAN ANYBODY HELP ME IN DISABLING THIS SWITCH MODE , OR GIVE A CODE TO IT , THIS IS A CHINESE NOKIA TYPE GFIVE E 71 MOBILE
Battre low problam
When your phone comes up with a battery low information, then it means you need to recharge the battery using the charger of the phone. If recharging using your charger does not help, then i will advice you get to insert the battery in another phone to try to charge there, it is definitely going to charge, when it charges fully, leave it in the phone phone and try to monitor the hours the battery lasts, if it last long, the the battery is okay, but if it does not, then it means the battery is weak bad need to be replaced.
Also test the phone by inserting a well tested battery that is fully charged into the phone and monitor how long it will last in the phone. if it last long, then the phone is okay, but if it drains off fast, then it means the phone is draining the battery, and that is the problem from the phones terminal head.
Also try to pad the battery in the phone with a folded paper so as to tighten the battery and make good connection with the phones terminal.
Also check the phones connection port.
Caseytech
My NOKIA 6300 has hanging
go to settings and restore the phone with settings then off ur phone for5min and on it again
it will be fine
Can i get the details of calls and sms from airtel prepaid number
you can get ur calls details ask ur airtel customer support to provide you. here let me tell you if u r using post paid then there is not a problem but if ur using prepay. i have a doubt but still airtel customer can provide you all the details if they want to
My nokia 6300 does not pick signals in office and
First remove the Simcard from the phone, test the SIM card on a different phone, and see if you get same reception problem in the office.
If the problem depends on the phone, then internal aerial contact is broken, get a replacement phone .
If problem depends on the SIM , then call the phone company, it may be a network problemt, or a reception problem because this company has poor field in the office area.
