20 Most Recent Furuno NavNet vx2 GP1720C GPS Receiver Questions & Answers
How do i connect my furuno navnet vx2 to my vhf
the output is on the black (blue) and white wires. in system setup, portsetup, you can select which sentences it sends out. 847-746-0100
7/6/2010 9:56:34 PM • Furuno NavNet... • Answered on Jul 06, 2010
Radar Displays the image upside down
If this is on the radar screen, you'll have to set your heading alignment on your radar. The radar may be 180 degrees out. if this occurs on the plotter, then if you have a heading sensor attached or an autopilot, your heading may be off.
2/1/2010 2:36:18 PM • Furuno NavNet... • Answered on Feb 01, 2010
How connect the nav net vx2 to autopilot
Get someone from a marine electronics company to do this for you. If you are unsure of the basics of what you need and you attempt to do this while going in blind, you may ruin your nmea ports on your navnet and autopilot. While I understand that you are trying to save $$$ by doing this, there's more to it than just wiring. There are port setups and nmea sentences to enable etc.
2/1/2010 2:30:50 PM • Furuno NavNet... • Answered on Feb 01, 2010
I can never read the fish on the screen
perhaps someone has messed with your sounder settings. You may want to factory reset the sounder from within one of the menus in your navnet. Also you may have a transducer going bad. Did you hit anything with it or run aground once? Maybe someone painted over the face of the transducer with bottom paint. There's alot of things that can cause this to happen. It would be best to have the sounder checked out before you do anything to the ducer. Remove your navnet and sounder and take it to a dealer to test on the bench. If you're in the maryland area, Mid-shore Electronics and handle this for you. Even if you're not, you can send the units to them.
2/1/2010 2:20:04 PM • Furuno NavNet... • Answered on Feb 01, 2010
Furuno GP31 Navigator. How do I can change language from German to English please?
Question edited for clarity.Page 75 of the manual refershttps://www.manualslib.com/manual/1183586/Furuno-Gp-39.html?page=75Menu - System - LanguageMenu (the U with two dots over it Umlaut) - System - Sprache..
4/1/2023 3:09:40 AM • Furuno GPS • Answered on Apr 01, 2023
What is the unit of measurement of the Furuno GP 1650 video sounder?
There are set by you to feet, metres, 'F or 'C, knots, kph, or mph.From a bit more reading, depth is Feet, distance is Nautical Miles. Temperature you have a choice.Note: The water temperature graph can beset on or off (See page 11-4.). The temperature scale is fixed between 20-80 °F (0 to30°C).Read the manualhttps://www.furunousa.com/-/media/sites/furuno/document_library/documents/manuals/public_manuals/gp1650fdf_operators_manual_version_m.pdf..
2/20/2021 9:03:42 PM • Furuno GPS • Answered on Feb 20, 2021
Furuno 1650F GPS. How do I replace the internal battery?
You would obviously be better served if you learned how to google it https://downeastboatforum.com/threads/1650-battery-replacement.12881/
9/29/2020 6:39:52 PM • Furuno GPS • Answered on Sep 29, 2020
How to connect furuno gp39 NMEA0183 to computer
https://www.youtube.com/watch?v=AQW4EoQPM00 hope this helps if so leave some feedback 8]
5/21/2020 5:53:32 PM • Furuno GPS • Answered on May 21, 2020
Our furuno fcv 587 will not turn on. Fuses appear to be ok
Possibly voltage too low, faulty unit, no power coming to the unit.
10/9/2018 12:49:30 PM • Furuno GPS • Answered on Oct 09, 2018
0answers
Furuno NavNet vx2 GP1720C GPS Receiver Logo
Popular Tags
8 questions posted
Top Furuno GPS Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Furuno GPS Expert? Answer questions, earn points and help others
View Most Popular
Furuno GPS
  • Furuno GPS
Most Popular Question
connect furuno navnet vx2 vhf
  • GPS
